4 STUD R32 GTS brake questions
I've been reading thru the forum trying to get information on replacing brake components for my 4-Stud R32 sedan GTS.
Before anyone suggests, I am staying 4 lug and do not wish to go 5-stud!
From what I've gathered so far, I can use S13/240sx Rotors and pads for the front no problem,
My issue is trying to find REAR rotors and pads.
Because they are in-drum, I'm not sure what I can use/ cross reference to here in USA. Iv'e found that I will use non-turbo 300zx e-brake shoes but trying to replace rotors and pads as well.
Any Info would be greatly appreciated!
Thanks!!
Edited by dylondylondylon
update
https://www.sau.com.au/forums/topic/471406-4-stud-r32-gts-brake-questions/
Trying to buy this stuff in the US might drive you nuts.  There is some chance that the rears are the same as S13 stuff, but I admit my care factor for pissy 4-bolt stuff and sliding calipers is so low that I have never known, nor will I.
Your best bet is probably to look outside the US.  Look to Nengun, Amayama, etc.
My first question has to be - if you don't want to upgrade to 5-stud, why do you want to replace the brake components in the first place? I'm not an expert in S13 stuff, but I would expect that the brakes on a S13 would not be up to the standard / capacity of a R32 (even a GTS R32).
Since the bulk of the braking is taken by the front brakes, I see little point in changing / upgrading the rear brakes.
Yea I've been browsing thru YahooJapan Auctions, croooober ect.
But that's mostly all used brake components.
Replacing the e-brake shoes because of extreme wear, which I will use 300zx Project-Mu product. The rotors also should be replaced because of wear.
I will just need to test fit and do measuring to see what will work here state-side, just figured someone might know off the top of their head or have replaced their 4-lug components so I could order ahead of time before she goes on jack-stands.
Lots of info can be found for 5-stud, and going from 4lug to 5 lug, but I'm keen for staying 4stud.
thanks for the input.
Just looked on Amayama , never heard of that site!
Got the measurements of the rotors and going to cross it with something over here.
thanks for the information, very helpful! :1310_thumbsup_tone1:
For anyone interested,
The front brake Rotors, and Pads are exact same as S13/240sx
-Diameter: 256mm
-Disk Thickness: 22mm
-Height: 49.2mm
-Center Diameter: 68mm
The rear Rotors are similar sizing to the Infiniti M30 / Nissan Leapord F31
-Diameter: 265.9mm
-Disk Thickness: 10mm
-Height: 69.5mm
-Center Diameter: 68.0mm
Hi, good to see someone else keeping the 4 stud hubs. I have an R32 GTS 2 door here in Oz and have not gone the 5 stud conversion route as there is nothing I am interested pursuing in that direction. And I still have awesome fun with my car as a daily and at track days. Thats all that matters.
Anyway, this site I found very useful, select Brake Upgrades and you get a whole lot of useful info.
https://en.m.wikibooks.org/wiki/Nissan_240SX_Performance_Modification
Funny that this was from the US but helped me do a modest front brake upgrade here in Australia. I fitted s13 turbo calipers and went from the stock 257mm diameter rotors to 280mm. The s13 turbo stuff is a direct bolt on for your fronts. The calipers are still single pot but just a fraction bigger piston so no need to change your brake master cylinder. I currently have DBA (Disk Brakes Australia) T2 slotted rotors (DBA919S) and some QFM pads (QFM DB1232 A1RM) and the result is awsome. I know DBA sell in the US so check that. For pads just look for s13 turbo stuff you can get. Dunno if QFM stuff is available in the US.
You are right about the rears they are not s13. You will find that R32 and R33 4 stud rears are the same but dunno if you can source R33 stuff where you are. Check that link above as I can't remember if it covered rears  Unfortunately I have not found rotors from DBA to do my rears  Another Australian company, Rotors and Disks Australia (RDA) do rears (part number RDA 7692) so could try ebay??
Anyway good luck with it and enjoy your car.
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
