Ok guys, in my quest to achieve a 290-300rwhp, 12 second 1/4 mile in my R32 GTS-T using only street tyres, my current plan of attack consists of the following modifications (some of which i already have on the car):
Full turbo back 3" exhaust with high flow cat.
GT2530
HKS Air pod
Hybrid 600x300x75 FMIC
Bosch 040 450hp fuel pump
Fuel regulator
Tuned ROM
Decent clutch and lightened flywheel
Some further considerations for the run:
Removing the rear seats for weight reduction, 1/4 tank of fuel, bottle of octane boost, stripping my boot completely and the driver (me) have a light breakfast and skip lunch. :D
Questions:
1. What street tyres will be the bare minimum size needed? I would like to to do the run using the standard gts-t wheels. Is it possible on 205/55's?
2. This is the most worrying aspect of my car, i have TEIN HE coilovers which are VERY stiff, is it possible to get traction and make the 12 with such firm coil overs?
3. What boost level would be most recommended for the run? Some have said 16psi, some have said 18psi....
If anyone can give me some experience based advice, recommendations or answers to my questions it would be greatly appreciated.
Thanks guys
https://www.sau.com.au/forums/topic/47142-12-second-plan-of-attack/
light brekky and skipping lunch will not make a difference (unless you eat like a horse).
try running 225/50's on the stockers...else you could get GTR rims which are 16x8 (as opposed to 16x6.5)
I'd probably get onto the track first and see what times you run. There's no use in us telling you to do this and that without knowing how far off you are from a 12sec 1/4. If anything a good launch will get you the most improvement.
Guest Robo's
Dont waist your money in upgrading turbos to dip into the 12's. If your not close with the 2350, you wont be any different with the 2535.
My tips are:
Deflate tyres to around 20psi
Do a good burnout to get some heat in them no matter what tyre or size they are
Try a few practise launches to get the feel of your clutch biting and grip (on the strip i can use more revs than the street)
Launching is the key, break out in wheelspin and youve lost it. Balance between revs and grip
Dont be scared to abuse your clutch if your looking for quick 60's
Make sure your gearshifts are quick.
Good luck.
The balance between revs and grip is a fine line for me.
I ran 225/55/16 tyres at the drags tonight and the clutch isn't up to scratch.
13.6@109mph (175kmh). 2.3 60ft.
I have coil overs (not as stiff as Teins)...but stockos would be better.
If i could get a flat 2 60ft, i would be running flat-low 13's.
My mods are similar to what you hope to do, cept for the clutch.
Hope that helps.
Scott
Hi Mate
Good goal you have to pull a 12.!! ANd i will agree that the difference between a high and low 12 is massive!.
Coming from just pulling a 12.5 @ 117Mph i can tell you that 20psi in ur tyres wont do anything think more like 8-10psi i was running this and helped hugely
Massive burnout heat em right up.
Dont worry about the tree just sit there and get your revs right, never go 1st 2nd hard becuase that inceases the chance of losing traction getting ur 60ft good is very important for your final time and ur MPH which is a huge sign of what your car is capable of. So run your car as it is then report back with your 60Ft time and your MPH and it should be easy to tell you what is needed performance/suspension setup to get your 12's.
I only had 2 runs before my clutch started slipping bad but ill be back in about 2 months for an 11 its definetly got it. I want to smash HPI's R34 Ive already got a higher MPH then them and I did my 12 second quarter on 40% tread 225's 17s standard road tyres.
Will be using 10Inch tread on 16 inch tyres Nitto's next time.
Good luck with your 12's mate its good fun!.
BR,
JH
Hi Guys!,
Yeah 2rismo cant wait my 60ft times were 2.4 hahah but I just came to test see what had to be done and tyres/clutch is definetly needed. Some cars there were running into the 10's with lower MPH's so IM keen to see what can be possible on the manual and see if its viable to go Auto.
Mods to date as the car was for sale and still to a point is, check them out at
http://www.impexpersonnel.com.au/skyline
My MPH should get over the 120 mark once i get my 60fts better if anyone wants a small clip of the video it was earlier tonight at WSID I can send through listen to the car scrabble for traction 3rd gear!!
Thanks for the interest guys
Times tonight where
12.569 @ 113mph- Have clip of this run if anyone interested.
12.501 @ 117mph
3rd Time when 4th gear slipped
13.044 @ 89mph
JH
Owner OnGate Performance.
japsky33, with 117mph and a 1.6 60' you have an 11.8-11.9 ET begging.  Good luck mate!
Adrian
see my sig for times. (beofre cooler and flywheel)
I looking for 12s (12.9) as I just fitted a lightweight flywheel which are reputedly good for 0.4 - 0.5.
Also bolted in front mount cooler which should add a touch.
PowerFC coming soon.
Definent 12s
Definetly should be 12's!
BR
JH
Definent 12s
WSID was designed to be one of the quickest, legal drag racing tracks in the world. There's alot of sneaky development that went into building the track, that all fits within acceptable rules. Little things like the maximum amount of downhill gradient allowed, track surface and base, as well as the U shaped design to mimimise headwind etc.
Guest Robo's
Hi Guys!,
Times tonight where
12.501 @ 117mph
13.044 @ 89mph
JH
Alot of mods there, i wouldnt be happy with anything short of 120mph.
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
    • Thanks for the quick reply. To be clear, when you say turbo shuffle do you mean turbo flutter "stustustu" or referring to something else? I had thought they were the same thing. When I wrote the post my intention was to say it wasn't a flutter/compression surge sound. My understanding was that a flutter sound would be occurring when throttle is released, whereas I can keep the throttle in the same position for this noise
    • Hi everyone, I've been wrestling with this for a while now and have been trying to find out the cause. For context, the turbos used are Garrett 2860 -5s, the BOV is a BNR32 HKS SSQV IV kit, the car is currently tuned to ~470 whp on 17.5 psi. The car drives normally, pulls well when it doesn't happen, and I can replicate it fairly easily. It does not sound like turbo shuffle or flutter. The engine has only a thousand or so miles and has had this behavior since it was completed. After my engine was built for my R32 GTR, I noticed that the car now sometimes makes an air discharge sound on what appears to be positive boost pressure that sounds really similar to a BOV. I had thought that it was a BOV issue but even when replacing it with a brand new unit, the sound persisted. It seems like it's coming from the passenger side but I may be mistaken. The closest scenario I could find was this post here https://www.gtr.co.uk/threads/maybe-a-boost-leak-opinions.147955/https://www.gtr.co.uk/threads/maybe-a-boost-leak-opinions.147955/ started by @yakshii and it sounds very similar. As in, at partial throttle once I reach positive boost I begin to hear the same psh psh psh psh psh sound like air is leaking somewhere when I keep the throttle in the same position. It most commonly happens in 4th gear at around 3-3.5k RPM and 5th gear around 2.5-3k RPM, which seems to coincide with normal positive boost thresholds. It might be similar to what @Austrian GTR mentioned about his own HKS SSQV. Notable difference would be that when he applies more throttle when it happens, it stops. In my scenario if I apply more throttle during this repeated psh psh psh sound, the cadence of the sound gets faster and louder rather than stopping. If I lift off slightly and apply throttle again, it will normally stop and pull without issue. I've checked all rubber couplers to ensure that they are tight, but have not gotten the opportunity to properly do a pressurized boost leak test. If anyone has had similar experiences or thoughts on what might be the cause, I'd be very keen to hear them. I also have a video of it happening from inside the cabin, if that would make it easier to understand: https://youtu.be/2zqZXcx8jbA
