R33 gtst missfiring problem?
Hi everyone,
This is my first post and I'm after some help. After reading many threads about people's misfires in their r33 s1 gtst I can't come to a resolution of my problem.
I have a fmic, full exhaust, 10psi.
Under full throttle any gear it makes a mini gun rapid fire out the exhaust with no power. Does not happen when gradually accelerating. I have replaced since it first started; fuel pump, fuel filter, spark plugs gapped to 0.9 (previous plugs were 0.8 and same issue), tried original and super spark coil pack both second hand. Still am having problems
Could it be my igniter? The problem was not there before I installed fmic and bumped up boost. I haven't yet tried sealing my coilpacks with high temp sealant.
I have my car booked in for highflow and tune monday so would like to get it fixed before then
Any advice would be awesome
Cheers Mitch
https://www.sau.com.au/forums/topic/471732-r33-gtst-missfiring-problem/
Sound's like R&R (rich and retard).
The stock ecu is seeing more air than it's used to so it tries to protect the engine by adding more fuel and retarding the timing. This would make sense since the problem started after you installed the fmic and raised the boost which would result in increased airflow.
This causes a loss of power and the misfiring feeling. You could try clean your AFM with some MAF cleaner and dropping the boost 1 or 2 psi, the problem should go away then.
Are you sure you are running only 10psi and not higher?
Hey,
thanks for your reply. I've got a 32ecu z32afm and a highflow + tune going in Monday. But I just want to make sure everything is working before I give it to mechanic and get charged an extra $100 an hour to repair my coilpack etc.. I'm positive only 10psi boost. I'll try cleaning my afm and I'll drop the boost back to 7 and see how that works
Problem(s) could be from either the Superspark coils (which are rubbish, sorry to be blunt) or faulty OEM ones.
Best to get Splitfire ones or go Yaris conversion or LS conversion coils.
Don't really want to spend $500 if I don't have too. Might try afm cleaner and see what tuner does. Do you recommend using that silicon or electrical tape around coils as a resolution?
Sure, none of us want to spend extra money but if your coil packs are buggered or you spent $400 when you should have spent $600 then the only way out is to spend $600.  Not $500 or $400.
Always buy Splitfires at minimum.  Do not try and go cheaper.  You will only end up opening your wallet again to buy what you should have bought the first time.
Doubt it's coilpacks as it wasnt like it before I bumped up boost, installed fmic and full exhaust
I wouldn't not doubt the coilpacks in that assumption. I'm not saying that it is your coils either but if they're weak it shows up when boost and power increases.
As above, if buying new coils stay away from the bright coloured ones unless they're the bluey purple ones, otherwise OEM or conversion.
I'm going to entertain the R and R theory.
Tried both coilpacks, and screwing boost tee fully which isn't making boost any lower then 9. Unsure why. Might have to plumb it back through my apexi boost controller which used to run stock boost 5-7psi. Will give that a shot tomorrow, if no luck, will try and tape coilpacks or look for cracks in OEM ones. Will R&R still occur when I lower the boost? I know it's running rich because I get 200-250km  tank and that's not even thrashing it
Just now, vxsr33 said:
So did you test drive it at 9psi and it's still cutting out?
Just take off the boost T and use a straight through connector if you have one. R&R shouldn't occur once the boost is lowered.
Yeah I'm going to put it through my apexi boost controller tomorrow arvo, which is turned off so it runs stock boost which it used to. This will tell me if r&r or coilpack
That should give you approx 5 psi (assuming you have stock turbo with stock actuator and the stock boost solenoid is eliminated) which will certainly eliminate any over boosting and R&R.
R33 stock ecu is notorious for freaking out around the 10 psi mark, sometimes you're lucky, sometimes not.
Definitely clean your AFM / MAF with the proper MAF Cleaner like CRC as even the slightest bit of crud can cause it to read incorrectly.
  • Like 1
Okay cheers man, I'll grab some CRC MAF cleaner tomorrow.
It's a little exxy but great stuff, I've used it on every car I've owned running a MAF and it has improved idle smoothness and fuel economy on all of them.
Should be part of your general servicing and maintenance routine but is often forgotten.
My R33 (running 10psi) did what yours is doing once but the MAF cleaner fixed it. :thumbsup:
Should be part of your servicing and maintenance routine but is often forgotten. :)
Okay thanks for that, if it nots the AFM or the fact it's running higher boost with a fmic, would you definitely say it's coilpacks? Since I've replaced pump and fuel filter already. Would you wrap coilpacks in electrical tape? And if so what part do you wrap? If your not sure all good man
No I would not as there's still too many variables. Start with the easy and cheap fixes and eliminate them first.
What pump did you put in? Did you feed it a new 12 Volt line via a relay or just use existing wiring?
Some after market pumps don't like old stock wiring.
Check the coils for cracking and wrap the whole long bit to eliminate any arcing if need be.
Existing wiring , walbro 255
Might be ok, but try the other things first (CRC and coil wrapping) and go from there.
Heaps of info in this site about all these things as they have all been covered many many times over, so have a mad search, read up on R&R, misfires, Fuel pump installs etc etc.
and go nuts!
I know I sure did. :yes:
    • Yep that is correct. It allows you to adjust the short throw range from what I can tell
    • Car has been running great, I've put about 300km's of break in time on it. First thing that stands out with properly sealing rings is no more noticeable crankcase smell coming out of my catch can. This may seem insignificant, but the constant smell while driving around was infuriating. It's also nice to see my oil level remain stable. Two new issues have developed that I only noticed this weekend though. There's a very noticeable driveline vibration past 100kmh. I only noticed it now as I've been babying it under 100kmh in the backroads. This comes as no surprise as I'm running a one-piece shaft, and I paid zero attention to my driveshaft angle when I put everything back in. I also have a fair bit of voltage drop on hot starts. The starter audibly is forcing. No issues on cold start though. I must not have removed all the paint under my main block ground during assembly. I'll try and take care of both those issues this week once the kids are asleep.  I also received all the parts I was missing for my direct port setup. I will hopefully have pictures of that up soon. I'm hoping to get back on the dyno the week of June 30th as I'll be on vacation. I'm confident I should be able to make north of 500rwkw on pump gas and WMI. I'll go back again later this summer with E98, but I want to confirm my ethanol content sensor is working properly first. I've never seen it read anything but 11%. This makes sense for our 10% ethanol content pump gas here, but I would expect the occasional movement between fill ups.
    • 75% complete. Will now need to get a new axle with 5x114.3 hubs and then figure out how to customize some mudguards for it once the wheels are on.
    • Trailer prep is underway... Lined up the wheel to get a rough indication of how it would sit Then removed all the bits (as far as possible) and gave the frame a light sand and quick lick of paint   Then added some carpet
    • okay, so I figured this out, removed needles and reinstalled after swapping the gauge face on my triple gauge for my ER34, all work and look good. I tried to do the same for the main cluster, but the main cluster gauge faces are dished, the replacement gauge face are flat, so due to the dish in the org face ,mounting backing plate (clear) and depth of the needle, the flat gauge face will not work. I notice that R34 gtr gauges are flat, appears to be different clear backing plate that aren't dished. are these available, or what have others done to install flat gauge faces?
