12 hours ago, MrR33SKI said:
Turbo lol. Ive gone with a rb26dett for the 33 gtst. Cbf for the head aches of having someone elses thrashed motor lol. Ill see what i hit on the dyno and post pics here. Thanks for all the help guys
Umm yeah, that's like saying you hate guns then buying an AK-47.
Boggles my mind how people think the 26 is much of an upgrade over the 25. Older engine design with more flaws; GTR taxed parts and less availability; more prone to catastrophic failure...all for a negligible increase in displacement and a different soundtrack.
  • Like 3
Don't forget them all being thrashed.
At least the RB25DET has a better chance of being less thrashed, especially if it's from an auto car (e.g. Stagea).
And that the newest engine you'll get is already 15 years old, a lot if people dont even realise that some of our favourite cars like the r32 gtr are already 27 ish years old!!!
God damn dinosaurs
Edited by Cyko34
  • Like 1
Constantly trips me out that my R33 daily is older now than VH Commodores were when I first got my licence...I thought VNs were old shitters back then lol (they were)
Car is running perfect now. No issues st all besides having stock power. Have had a long think about it and came to the thought of just keeping the car stock and healthy. Also i have decided i would like to get a s15, evo7, and/or supra for a weekend car and keep the skyline as my daily.
This might sound stupid but if your burning through lots of oil check your PCV valve is working correctly
I’ve recently gone through a similar exercise with my Dads landcruiser which was using about a litre per 1000km
It’s done 305,000kms so we thought it was just worn rings. However I decided to pull out the PCV valve to check it, and it was stuck open. The vacuum hose going to it had split, so it didn’t have enough vacuum to open and close it and it got stuck
Cleaned it out with some solvent, put a new hose on and it’s using bugger all oil now, running sweet
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
