JEM reckon my car will make 350ish when i go back to E85, after i fix a couple of issues (that i told you about the other day Luke)
Realistically if you want 400 -9's will struggle as well...you'll either need -5's or a nice single. considering a precision turbo is cheaper than -5's id just do that, get someone to fab you a manifold.
In saying that i'm weighing up my options for my next turbo, because im a stubborn flamin mongrel and a but of a "purist" ill be sticking with 2 turbos....
If the motor is healthy you should be able to push around 350kw on E85 with the -7's. Spend the extra cash on the diffs, and enjoy.
350-400KW, Quaife front Diff, modified transfer case, nismo rear diff=ultimate street car IMO
I thought 5s wpuld be much higher on e85, considering theure 380+ on 98???
-5's will make 450+ on E85
Do you need Plazmaman Comp Series 100mm p0rn cooler? I always do breast pry for SAU members
I hope those aren't CNG injectors [emoji4]
For the 7s, stock cooler should do me.
Think 100 would be too large.
As thinking about the 80 series.....
And injectors were 2nd hand, so not 100%
Just now, Piggaz said:
For how long? Not very ?
realistically, a set of -5's should be pegged at 410 ish for trackwork. Heat, heat, heat.
Oh yeah i was more talking about street work. TBH for a track dedicated car a single is the way to go 100%.
22 minutes ago, luke gtr said:
Have heard of 7s making 380 on e85.
Thats why I though the 9s may just touch the 400.
380? f**k that would be pushing them hard... on a 2.6?
Take a photo of the injectors, tbh if they are CNG ones sell them ASAP... they're not worth your time.
400 kw at the track is -5's. Minimum. Can't expect -7's/-9's or whatever to last at high 300's at the track. Shit will be glowing red, melting. Kinda have to "relax" everything considering the punishment.
"Intune's" R33/RB30/-5's/e85 which was making 424 rwkw lasted 6 laps at Sandown, rear turbo popped. Pulled them off and it's was totally rooted.
My -5 setup lasted 2 trackdays (which they were turned down) and no more than 5000 road kms. Rear turbo was cactus.
A street car making "x" with everything wound up ain't going to last long hauling ass up mountain straight lap after lap.
Forget -9's buttplug's. If you want 400, you NEED -5's at a minimum.
  • Like 2
Twins are gay, single twin scroll, twin gates (or single but split to the gate) done deal.
Look at BMW when they started to have a play with turbos on their inline 6 on the N54 motor.. they though "twins are sick, twins for response".. yeah nah bro, not even a new chassis or generation and they fixed up their cock ups with a N55 motor and slapped a single twin scroll. It took them all of 3~4 years to realise twins on an inline motor was stupid.
You GT-R boys have had since 1989 and still get it wrong.
Paul was a homo cnut too.. but after years of me whinging (and others) he became a man.
#truestory lol
BTW.. I voted YES.
  • Like 1
    • When you crank your car, and hit it with a timing light, can you see a steady crank timing?
    • Oh, forgot to add, A few months ago I was getting mixture codes and the car was using crap loads of fuel. You could smell the unburned fuel in the exhaust, it was crazy strong. Economy was over 17.5 l/100 and usually around 19. I smoked the engine and found a leaky CCV hose which I replaced and then I replaced my two pre cat O2 sensors, I also replaced the MAF. This fixed my mixture codes and improved my exonomy but I'm still 14 - 15 l/100 when pottering about town so something is still amiss. Throttle response is much better and it has more pep but I'd like to know why it's still so thirsty (and I'm hoping that whatever it is gives me a bit more poke).
    • Car is on factory injectors/z32 maf/ q45 throttle body/ z32 ecu with nistune
    • Hello all, currently finishing up a rb25 swap into my s14. Having issues with starting, car has spark (confirmed by pulling a plug and watching it spark), has fuel(confirmed by checking pulse/voltage at injectors all spark plugs are soaked in fuel). Car cranks over and pops into the exhaust with a heavy fuel smell but no attempt to start or run, I have torn the timing cover off and triple confirmed timing, turned the CAS in multiple spots both directions, attempted to start with coolant temp and maf unplugged, checked my fuel lines and made sure they weren’t backwards, checked voltage at cas/injectors/coilpacks, made sure all the grounds in the harness are connected and added a few grounding straps (1 from chassis to block, 1 from chassis to head, and 1 from chassis to igniter chip) I am getting stumped here. As a last ditch effort I made a full grounding harness tonight that’s going to run from the battery and add an extra ground from the battery onto the coil pack harness/igniter chip/ intake manifold/ Wiring specialties harness ground/ and alternator. I’m hoping maybe the grounding harness will fix it here but posting here to see if anyone has any other ideas on what else I can check. My fuel pressure is unknown right gauge will be here tomorrow.  IMG_3206.mov
    • yeah I was shocked when I checked my spare OEM on and as below that's how they come from Nissan. (side interesting note new NEO gearbox and replacement park lack the brass bush on the tips and its just all alloy) unsure about damage to the box currently back at 1110 to be pulled down/inspected and selector fork replaced as he built it previously and given the never before seen failure on his billet forks he is replacing it under warranty. He said he has used always OEM the keyway tab without issue for years so it could be an unlucky coincidence. I did talk to him about the sharp corners and stress concentration too. Re: hard shifts i got 7+ years out of the OEM one and the fork itself failed not the keyway. so could be bad luck as I said or an age thing + heat cycles in box and during fabrication of billet?
