Gold:
Ok, knew I had metal throttle body gaskets somewhere. They reared their head on my toolbox at work today. Glad I hadn't put the motor in, or I wouldn't bother, as it's a PITA.
So, removed plenum, throttle bodies and IAC assembly.
Installed metal gaskets(with a hylomar coating) and reassembled.
Will be a good addition if I ever swap to e85 and start trying more boost.
White:
Washed to carbon bonnet that has been sitting in the garage for about a year.20181012_145844.jpg20181012_155413.jpg20181012_155415.jpg20181012_155708.jpg20181012_160748.jpg20181012_150355.jpg
  • Like 1
Gold:
Busy day yesterday.
Connected heater lines, injector harness, coolant and air temp sensors, main earth and alternator wiring.
Also installed clutch, gearbox, tailshaft and front exhaust merge pipe.
Have also connected the ps drive shaft.
And popped bonnet back on.
  • Like 1
Gold:
Wasnt going to do anything today, but I ended up doing some work.
2x boost pipes connected
Intake pipes and air box fitted
Bov recirc pipes and hoses fitted
Ac belt on
Reconnect throttle cable20181015_193146.jpg20181015_193153.jpg20181015_193203.jpg20181015_193207.jpg
  • Like 1
Looking good mate good progress
Keep the pics coming
Cheers mate.
Honestly surprised no one has bagged out the stock air box.
I was curious to see if it would work with the 30 bottom end. Was a little tight, but got there.
Gold:
What did I get done today?
Read on to find out....
Purchased some oils and drive belts(also purchased drive belts for the white one while I was there)
Installed said belt(power steer)
Installed radiator
Installed shifter assembly
Installed strut brace cross bar
Installed centre muffler section of exhaust
Finished filling with run in oil(I was 2l short from my last lot)
Filled with coolant
Was going to fill transfer and diff, but couldnt crack the transfer fill plug.
Checked and confirmed i also need gearbox oil(dont know why I drained it)
Painted the exhaust tip black again, as the paint had perished.
Any other questions?
20181016_180952.jpg20181016_182038.jpg20181016_182435.jpg20181016_182828.jpg20181016_185826.jpg20181016_193124.jpg20181016_193249.jpg
  • Like 1
On 10/16/2018 at 7:59 PM, luke gtr said:
Depends on blue slip inspection.
Need to find someone a little lenient.
Anyone know anyone?
There is a guy that posts on the facebook pages peter gtr or something like that, says he will do blues.
Edited by NEO25T
Spelling
Gold:
Rear muffler on
Starter motor in!(was procrastinating because it's a PITA)
Transfer oil in
Lower bell housing bolts in
Connected fan wiring
Still have to connect the starter wiring, fit clutch slave, fill front diff and gearbox.
Then, should be good to go.
No pics today(sorry)
Called it a little early as my light went flat.
  • Like 1
So........
Gold:
Starter motor wiring connected
Clutch slave bolted up
Front tail shaft installed
Gearbox filled
Front diff filled
Battery connected
And started for the first time in over 2 years!
Fark yeah!
Also washed it. Feels so good.
(Unfortunately I have an oil leak. I suspect the front turbo oil feed. Will check it out tomorrow)20181019_185408.jpg
  • Like 3
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
