Didn't even intend to buy another R32, after purchasing an ADM from Bob.... but this was too good not to bid on;
One owner
12,766 km
HKS muffler
Tommy Kaira Recaro seats
A/m HID lights, air cleaner
Sports clutch
A/m fog lights and 17" wheels
Cusco tower bar
Mbro corner lamp
A/m adjustable suspension
Remote / TV will come later
Sideskirts a/m ? small dent (couldn't see it)
Centre console has a small scratch
Dash has small glue mark
  • Like 1
https://www.sau.com.au/forums/topic/472215-new-purchase-r32-tommykaira-45b/
Congratulations on the purchase........... Interesting car.
How's the black car going?
Any pics? Updates? Anything?
It's one of the few cars I actually regret selling.:1_grinning::1_grinning:
Cheers...... Bob.
Cheers...... Bob.
Hi Bob,
I had it in at Galvsport here, had the clutch swapped out for a standard unit, short shifter removed.  Aircon is on the blink, they've already looked at it once, but still needs fixing (something with the switching/computers).  They also went through all the usual things, made sure all is sweet.
Also had some issues with the brake master, unfortunately made the mistake of using a local mechanic who had a reconditioned (twice) but apparently there's an issue with reconditioning those units (leaves sharp edge on sleeve) which causes it to fail again.  Long story short, Galvsport replaced it with a later model unit.
Haven't any photos at hand, but certainly still looks the same!  See below for what the mechanic wrote re aircon.
Cheers,
Peter
I’ve gone about as far as we can go with the GTR, I’ve got everything sorted but im struggling on the Aircon. There is an intermittent electrical gremlin somewhere between the Climate Control Module and the Fuse Box. Under some situations the signal is lost and we lose drive to the compressor. I can manually engage the compressor and get good working aircon, but I cant make it work automatically (which is no good on the road). The reason I’ve not got this totally finished, or pushed further is to primarily get in touch and let you know where we are and also my time over the next couple of weeks is soaked with preparations for our Targa event so id made sense seeing as its 2 degrees outside to work towards getting the car back to you and we can address this after the chaos dies down a bit.
I have also got the misfire sorted, we had two issues causing it – One was the coil pack harness that connects the ignitor box to the coil packs, the other was the coil packs themselves producing weak spark (one normally causes the other). I’ve replaced both of these and the car drives perfectly. Obviously buying a set of coilpacks was not part of the plan, however one of the positives is your injectors initially tested perfectly so we didn’t need to clean (or charge) for any work with them.
Re, the aircon. I had a similar issue with my r33, would run intermittently. Ended up being a bad connection on the plug for the thermistor which is a little temperature probe thats in the evaporator box under the dash. Worth a look since they cant work out what's going on.
  • Like 2
4 hours ago, petemac said:
Hi Bob,
Also had some issues with the brake master, unfortunately made the mistake of using a local mechanic who had a reconditioned (twice) but apparently there's an issue with reconditioning those units (leaves sharp edge on sleeve) which causes it to fail again.  Long story short, Galvsport replaced it with a later model unit. Haven't any photos at hand, but certainly still looks the same!  See below for what the mechanic wrote re aircon.
Cheers,
Peter
Hi Pete, nice to hear from you.....
The clutch and shifter I get, I too would have changed those had I kept the car.
The other items surprise me as all was working well when I sold it to you.
Admittedly, that was a few years ago now.
How long after buying the car did the air-conditioning and master cylinder play up?
Ta...... Bob.
2 minutes ago, petemac said:
Hmm, probably 12 or 18 months.... Just normal wear and tear I guess for vehicle of that age.
Oh ok..... As long as it wasn't 5 minutes later! :D
I'd be happy to buy it back at your purchase price, plus all repair costs, transport costs plus 3% interest compounding per year you have had it, plus your rego fees plus freight back to Sydney..........
Deal?
Bob.
For those interested, with the Tommy, was happy to get confirmation on the original service records....Quoting below my agent Geoff from Prestige Motorsports (highly recommended).
You have records starting in 1994 (13 Dec 1994 at 6 months old and 569km), then 14 June 1995 at 1,950km, 16 June 1996 at 5,905 km, 24 May 1997 at 7,355 km, 21 July 1999 at 9,040 km, 26 July 2001 at 9,908 km, 28 July 2003 at 10,907 km, 28 Aug 2005 at 11,546 km, 2 Oct 2015 at 11,839 km.  So in that 10 years it travelled less than 300 km and didn’t go back to Nissan for any more servicing, just kept in a garage and you can imagine all sorts of situations that may have led to the diminished use then the car finally being sold – perhaps something happened to the owner or their circumstances changed.
The latest inspection was done in October 2015 at 11,839 km and the following items were replaced:
Engine oil
Oil filter
LLC
Brake fluid
Drain washer
Radiator drain cock
Radiator hose (2)
V belts (3)
Fuel tank
Fuel pump
Fuel filter
Fuel gauge unit
Fuel hose (7)
Fuel additive
Front suspension upper link (2)
Front wiper refill (2)
Rear wiper blade
Bob,
Just took the ADM out for a quick spin - have to excuse, car is filthy.
image.thumb.png.7131cee945abbdae899503115ddc235e.pngimage.thumb.png.ab84c0dd7724ee9ffa83ef394e54bc42.png
Well done!!!!!!! Good to see it went to a respectful owner......
I'm just about to leave as my AH3 ADM is participating in a Pride of Ownership Day today.
This is a pic of her after a quick wash yesterday..
Cheers,
Bob.
  • Like 1
Wow Geoff has been in the game a long time. I remember looking at getting a car through him 13-14 years ago :O
I think it was a flat rate fee for their services too, like $1000.
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
