4 hours ago, ActionDan said:
wouldn't start. Luckily I always have my ODB2 dongle in the car, plugged it in and cleared the speed sensor fault code and away it went.
what kink of bullshit car wont start with a speed sensor fault? That's a bit rough.....
Shit ones apparently.
Full disclaimner, the fault I reference is only what Torque Pro told me it was.
It behaved like a bad crank angle sensor, BUT that wouldn't just be fine after clearing the fault if the sensor itself was bad.
So I assumed vehicle speed input is tied closely into the safety systems and causes a no start when present.
Edited by ActionDan
10 minutes ago, ActionDan said:
e85 leans out with heat? That's a new one for me.
Heat soak from returned fueul from engine bay or from don spec mega fuel pumps?
Also keen to understand this one. :)
Heat soak from returned fuel from engine bay or from don spec mega fuel pumps?
Not much to understand
do more laps fuel gets Hot doesn’t burn as well
ad fuel cooler and all good ( or add temp compensation to your tune)
thus why race cars have logging so ya can check shit
    • No, code 21 is very straightforward. It can only be the things described in that diagnostic flow. In fact it has no way of knowing that the spark plug resistance is out of spec.
