Hello again fellas,i finally realised my problem with my rb25 today an i was wondering if yall cud help me out...so its pretty simple actually...but im not  a electrician.So basically when the car uses other electrical components(like windows,A/C) ; it causes my air fuel gauge to read lean gradually till the car cuts off....i was hoping anyone cud tell me the wire which is wrong/bad,Thanks for any help in advance
https://www.sau.com.au/forums/topic/472311-rb25det-electrical-problem/
That's worrying, either your car isn't providing enough power and if so your battery will probably die soon because its trying to make up the difference or the power is going somewhere else probably as heat, look for melted or damaged cables and check electronics that cause this issue for a weird smell
2 hours ago, tishan said:
Okay thanks ..i am sending it to an electrician soon..u think wrong wiring could cause this?
Definitely an issue with wiring. The fuel pump sounds like its losing voltage and isnt supplying enough fuel which is causing a leanout condition.
Whether that wiring issue is an error or a burned or meltes harness you really need to go through and check everything.
Okay thanks i will let uk asap wen its finished by the electrician
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
