if you dont have it just let me know the model code on the japanese id plate and i will enter it into the software and check for you, my code is ecr33 108 722 or something like that from memory so yours will be similar format i assume
bnr32 011 611
i would repair the crack with superglue and baking soda or plastic powder, you start by putting some powder in the crack and then applying a little superglue onto the powder, it will be absorbed into the powder, then ann more powder to fill the crack and a bit more superglue, it dries fast and is stronger than just superglue on its own
  • Like 1
16 hours ago, Missileman said:
Know anybody with a 3D printer???
i'd join a group buy for it to lessen the scanning/cad .
3 hours ago, Mick said:
it will work, im sure other people here know about the superglue and baking soda trick, if you dont know about it just youtube it, you will be amazed
the problem is the plastic is dried out and will crack else where :(
https://imgur.com/a/s1Ag2
google the superglue and baking soda and use that to repair it, trust me it will work good and if it ever cracks in another place just do the same again, you will be amazed at how well it works, i saw a clip of a guy repairing his plastic radiator using it, an another guy who filled a big hole with it and them drilled trough it and then run a tap into it and then put a bolt in it, i dont know if plastic powder would be better or baking soda, but research it a little. At least it will work until you can track down some new adjusters one day
did you build it up slowly, like pack a little powder in the crack and then just a tiny drop of glue and let it seep in then a bit more powder then a bit more glue, till it builds up then file or sand or cut the access off to shape
hey i was doing some googling and i found something on a 300zx site that talks about some mod that you can hook upto the headlight that you can electronically adjust the headlight from inside the car, and it shows a pic of the same headlight adjuster that you are looking for
https://aus300zx.com/xenforo/index.php?threads/headlight-adjusters.273864/
boom!!! i just found a little kit you can use to replace the plastic gears in the adjuster bit you have a photo of and the other bit on the headlight that it meshes up to, take a look at this page mate, they are replacing there plastic gears with them
http://www.pexcom.com.au/z32cms/e107_images/H-L_Disassembly.pdf
  • Thanks 1
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
