if you dont have it just let me know the model code on the japanese id plate and i will enter it into the software and check for you, my code is ecr33 108 722 or something like that from memory so yours will be similar format i assume
bnr32 011 611
i would repair the crack with superglue and baking soda or plastic powder, you start by putting some powder in the crack and then applying a little superglue onto the powder, it will be absorbed into the powder, then ann more powder to fill the crack and a bit more superglue, it dries fast and is stronger than just superglue on its own
  • Like 1
16 hours ago, Missileman said:
Know anybody with a 3D printer???
i'd join a group buy for it to lessen the scanning/cad .
3 hours ago, Mick said:
it will work, im sure other people here know about the superglue and baking soda trick, if you dont know about it just youtube it, you will be amazed
the problem is the plastic is dried out and will crack else where :(
https://imgur.com/a/s1Ag2
google the superglue and baking soda and use that to repair it, trust me it will work good and if it ever cracks in another place just do the same again, you will be amazed at how well it works, i saw a clip of a guy repairing his plastic radiator using it, an another guy who filled a big hole with it and them drilled trough it and then run a tap into it and then put a bolt in it, i dont know if plastic powder would be better or baking soda, but research it a little. At least it will work until you can track down some new adjusters one day
did you build it up slowly, like pack a little powder in the crack and then just a tiny drop of glue and let it seep in then a bit more powder then a bit more glue, till it builds up then file or sand or cut the access off to shape
hey i was doing some googling and i found something on a 300zx site that talks about some mod that you can hook upto the headlight that you can electronically adjust the headlight from inside the car, and it shows a pic of the same headlight adjuster that you are looking for
https://aus300zx.com/xenforo/index.php?threads/headlight-adjusters.273864/
boom!!! i just found a little kit you can use to replace the plastic gears in the adjuster bit you have a photo of and the other bit on the headlight that it meshes up to, take a look at this page mate, they are replacing there plastic gears with them
http://www.pexcom.com.au/z32cms/e107_images/H-L_Disassembly.pdf
  • Thanks 1
    • You won't need to do that if your happy to learn to tune it yourself. You 100% do not need to do that. It is not part of the learning process. It's not like driving on track and 'finding the limit by stepping over the limit'. You should not ever accidently blow up an engine and you should have setup the ECU's engine protection to save you from yourself while you are learning anyway. Plenty of us have tuned their own cars, myself included. We still come here for advice/guidance/new ideas etc.  What have you been doing so far to learn how to tune?
    • Put the ECU's MAP line in your mouth. Blow as hard as you can. You should be able to see about 10 kPa, maybe 15 kPa positive pressure. Suck on it. You should be able to generate a decent vacuum to about the same level also. Note that this is only ~2 psi either way. If the MAP is reading -5 psi all the time, ignition on, engine running or not, driving around or not, then it is severely f**ked. Also, you SHOULD NOT BE DRIVING IT WITHOUT A LOAD REFERENCE. You will break the engine. Badly.
    • Could be correct. Meter might be that far out. Compare against a known 5 ohm 1% resistor.
    • @Murray_Calavera  If I were an expert I wouldn't be in here looking for assistance.  I am extremely computer literate, have above average understanding on how things should be working and how they should tie together.  If I need to go to a professional tuner so be it, but I'd much rather learn and do things myself even if it means looking for some guidance along the way and blowing up a few engines. @GTSBoy  I was hoping it would be as simple as a large vacuum leak somewhere but I'm unable to find anything, all lines seem to be well capped or going where they need to be, and when removed there is vacuum felt on the tube.  It would be odd for the Haltech built in MAP to be faulty, the GTT tune I imported had it enabled from the start, I incorrectly assumed it was reading a signal from the stock MAP, but that doesn't exist.  After running a vacuum hose to the ECU the signal doesn't change more than 0.2 in either direction.   I'll probably upload a video of my settings tomorrow, as it stands I'm able to daily drive, but getting stuttering when giving it gas from idle, so pulling away from lights is a slow process of revving it up and feathering the clutch until its moving, then it will accelerate fine.  It sounds like I need to get to the bottom of the manifold pressure issue, but the ignition timing section is most intimidating to me and will probably let a pro do that part.  Tomorrow I'll try a different vacuum line to T off of, with any luck I selected one that was already bypassed during the DBW swap.  (edit: I went out and did it right now, the line I had chosen did appear to have no vacuum on it, it used to go to the front of the intake, I've now completely blocked that one off at the bracket that holds several vacuum lines by the firewall.  I T'd into the vacuum line that goes from that bracket to the vacuum pump at the front of the car, but no change in the MAP readings).  Using the new vacuum line that has obvious vacuum on the hose, im still only getting readings between -6.0 and -5.2.  I'm wondering why the ECU was detecting -5.3 when nothing was connected to the MAP nipple and ECU MAP selected as the source. @feartherb26  I do have +T in the works but wanted to wait until Spring to start with that swap since this is my good winter AWD vehicle.  When removing the butterfly, did it leave a bunch of holes in the manifold that you needed to plug?  I thought about removing it but assumed it would be a mess.   I notice no difference when capping the vacuum line to it or letting it do its thing.  This whole thing has convinced me to just get a forward facing manifold when the time comes though.
    • Update: tested my spark plugs that are supposed to be 5ohms with a 10% deviation and one gave me a 0 ohms reading and the rest were 3.9ohm<, so one bad and the others on their way out.
