Hi my r34 gtr always run lower oil temp since i import it 2 years ago. and now even lower with some addition mods like nismo thermostat, and big oil sump etc.
At moment it run max 75C(normally around 60c-70c depend outside temp) oil and 70C water on street. if i push it hard for 10 mins the oil temp still around 90c, water temp below 80c.
the car has nitto oil pump, high octane 9L sump, nismo oil cooler.  arc intercooler, nismo radiator. car is running e85 made near 500awkw.
should i worry about the oil temp?  i'm start thinking i got bad sensor:(
If you're running 10-40/50 synth oil, perfect operating temp is around 90 deg as far as i'm aware.
I'm running a Tridon 71 deg thermo i think. Sits on 80-83 deg in normal traffic and cruising.
You can tune around the lower temp using fuel/temp corrections, but 70-75 seems a bit too cold for these engines????
i'm not really worry about the water temp, but the oil temp look too low for me. the oil temp only go up to 80C+ when in really bad traffic like 10 mins drive 1km. i use 10w40 or 5w40 oil. maybe i should change to 5w30?
21 hours ago, GTSBoy said:
Oil and water in contact in the HX.  Warmer water = warmer oil too.
yes true. but even before i put the nismo thermostat the oil temp still that low.  with the nismo thermostat only the water temp goes lower which is normal for low temp thermostat.  i did a short drive today, found the oil temp did go up to 75c in city with a lot stops. water temp is around 70c if i cruising around , but it go up to 85c when stuck in traffic.
Get rid of the Nismo thermostat and replace with stock. Get a thermostat for your oil cooler and/or make a cover for the oil cooler when you are not thrashing the car. (maybe you are not pushing it hard enough!).
You are right. I did not pushing it hard enough:) but Is there any long term effect from the lower temp? The car drive perfectly. Power always there.   And I change oil every 3000kms or sooner.
I think Nismo oil cooler should include the oil thermostat plate?
3 hours ago, GTSBoy said:
Yes, running engines too cold increases wear, and fuel consumption (assuming tune is not adjusted to suit).
thanks for reply.  i will try use some cardboard block the oil cooler and see the different. my tune is suit for low temp no problem.
I recently installed oil cooler and gauges in my car.  I actually didn't think too much about the oil temp being too cold.
My gauge starts at 50.  I warm it up, then baby it, revving to 2500 until the gauge starts to move, but it never really gets more than 60 driving.  Running it hard through the hills it might maybe go to 70 and on the racetrack will go to 70-80 max.
I am running 15-60w penrite/nulon.  Should i be concerned or do anything ? The cardboard idea was good...
Greddy oil cooler located drivers side
It's not the 10 in 10-40 that you should consider changing down.  It's the 40.  The smaller number is the "winter" viscosity, which essentially how it behaves dead cold.  At 70 ish degrees, you're not talking about that end of the oil's rating, your talking about the normal end.  So if you're running 40 now, then 30 would be the logical decrease, if you were going to try to deal with your possible low-oil-temperature-causing-high-viscosity problem by running thinner oil, that is.
  • Like 1
    • GCG is a good company, they're a major distributor for Garrett in Japan as well.
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
    • Ok thanks 🙂 I will higly consider this. Any "known" company for a good reviews and experience to send that off? Is that CJ-motor good one? Or go straight to GCG site? I need to use VPN to even find some of those "shops" let alone access them 🙂
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
