I don't really contribute hear at all but I need an opinion.
I've had a RB30/Neo 3.4 Stroker built at a workshop. Whilst at the workshop the shop relocated. The mechanic wanted me to pay a towing fee between his old and new workshop, I did although didn't think it was fair. Then he got in trouble for having too many cars at his new workshop so he had it moved to my house whilst the engine was being built, I paid towing once again. And now the engine is back in and the piping work needs to be done. He has it being towed to some other workshop to be done and wants me to pay towing again. Towing too and from $70 each time! I don't think this is right/fair. What do you think? What should I say or do?
Absolute bullshit. I am of the opinion that you really shouldn't have had to pay for any towing at all, but if you had to split the towing 50/50 with him that wouldn't be too bad either.
I would ask him face to face why he exects you to be paying for the towing and see what his reasoning is.
I agree with the above. Were you made aware he was moving shops?
So your mechanic moves shop and gets you to pay the towie then finds out he csnt even keep the car there and tells you to come and get it? I wouldnt bother going back lol
Edited by WantGTR
Edit
Tough call...
Was the vehicle in a driveable condition when you dropped it off? If so, then I think mechanic should wear the cost of towing to new workshop. It wasn't your choice for him to move workshops so that sucks and you probably shouldn't have had to pay for that one, but certainly if they have to tow it to other places to be worked on, then that one would be on you...
Down the middle sounds fairer?
  • 2 months later...
Thanks for the comments, I just let it go because I've just had enough of dealing with him. He charged me $50 p/h for labour so I don't really mind that much. The last time it got towed was to have an exhaust and intercooler piping made, I paid to and from and wasn't told until he had to pay for it. My car is done now and I will be collecting it from Tassie and bringing it back to Victoria in 2 weeks :D
f**k that, if he chooses to change shops it is his choice and his cost
if he needs to out source work which he always stated would be outsourced you should pay it
if he needs to our source work which he was supposed to do but cant he should pay it
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
