Neat and tidy Sonic Silver, 1996, Series 2, Manual, 4 Door Skyline with a genuine 273 RWKW.  (Northern NSW)
(Some may recognise this vehicle from these forums)
This car is an excellent example and it has been a joy to own.
Very reliable Canberra Car imported locally in 2002. 210,000Kms. Just moved to the Northern Rivers Area (Lismore, Lennox Heads-Alstonville) which is where it is now.
Great condition for it's age, and always serviced every 5000kms with quality products. Perfect for those who want an import while keeping the missus happy with doors for kids and groceries. Mature owner.
Modifications are:
-Genuine Garrett 3071 Turbo with braided lines and aluminum intake pipe.
-Vi-Pec Engine Management System, tuned by ESP in Queanbeyan
-Front-mount Intercooler
-Upgraded 040 fuel pump
-Upgraded 700cc (approx) injectors
-Split-fire coil packs
-Heavy duty clutch
-Full X-Force exhaust system
-Biggest pod filter you have ever seen
-Re-shimmed and serviced LSD Diff
-Whiteline swaybars front and rear with new knuckles
-DBA slotted brake rotors, braided lines and Project-Mu Pads
Body has a few scratches consistent with it's age, but I recently had the front and rear bar resprayed.
Interior:
- Great JVC stereo with new speakers all round and a pro-installed amplifier. Includes bluetooth.
- Turbo Timer
- New gearshift and handbrake leather boots
Servicing:
- Timing belt, water pump, idler pulley replaced at 198,000
- Serviced every 5000K's with Castrol Edge 10-60
- Recently serviced gearbox with new fluid
- Regularly detailed with Dodo wax products
Miscellaneous:
- New battery
- Really beautiful dark tint
- Ice cold air-conditioning
Spare set of wheels available aswell.
  • 4 weeks later...
Sadly this is now sold.
You all will find this has returned South and a member here has wisely purchased this sweet rig.
Right on
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
