HI All,
I'm moving and have these to offer:
Pick up in Greenacre - 0414 509 399 Spiro
R32 GTR Engin wiring loom $300
RB26 sandwich plate with throttle bodies and linkages
HKS R32 GTR coil overs - $800. Front top hats show some wear but work well.
Buddy Club coil overs - $300 - One of the rears is dead. Buy the fronts and get the rears free. Came with the car dead.
Zeal coil overs - $300 - One of the rears is dead. Buy the fronts and get the rears free. I killed this one.
Front Hubs $50 each
Coil packs, brackets and Harness - $200
Mirrors and Tail lights, $25 each,
ABS - $50
steering surround - all four parts $40 - I cant see the key lock piece.
r32 gtr Attesa oil reservoir - $60
Power steering reservoir - $25
R33 GTR muffler $100 -
R32 front sway bar, brackets, and links. $50
eXedy twin plate - I need to pull this apart to see the wear and tear - Let me know if anyone is interested.
Nissan cooler box???? funny. Pulls out of glove box.
20171212_184702.jpg.5036a7c98815f590556a42805f5cc7c8.jpg20171212_184706.jpg.5cd68c2357ba440a40f048c4a3d3b911.jpg
Managers here now so i cant finish this post..... Im just going to add the pics, Als im tired now. let me know if you see anything in the pics that you want. parts from $5
20171212_184434.thumb.jpg.0e5f846d235c31b2b812fcac4d281120.jpg20171212_184431.thumb.jpg.a7421121c1558df977069323e5c37eeb.jpg20171212_184425.thumb.jpg.194f0f475a4cf9a576b5852fa480d091.jpg20171212_184422.thumb.jpg.0d276c9355f9f9af07d4579ff6690e60.jpg20171212_184416.thumb.jpg.f504a49cffb94a976f8a5b445a4cedf4.jpg20171212_184436.thumb.jpg.e5fae87db5c036be0ec917eace4153d8.jpg
20171212_184405.thumb.jpg.d2fa3eebeaae265275677f2fc05ae0ba.jpg20171212_184408.thumb.jpg.a7d551dc7b04c109abc00f322e5eed42.jpg
20171212_184744.thumb.jpg.64a2de0fd36b86a7a9cb2418a69a97c8.jpg20171212_172722.thumb.jpg.811ef537131d3143ada9472ef41c21a9.jpg
Cheers
imageproxy.php?img=&key=4b1e78680f916b86imageproxy.php?img=&key=4b1e78680f916b86
Edited by spirom
https://www.sau.com.au/forums/topic/472909-r32-gtr-parts/
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
