Hi Guys,
I haven't forgot about the indicators integrated with the GT badge! i have just had a heap of work and other more pressing projects on the go lately..... one of them being this.
As many have before I have deleted the air con on my 32... but unlike most I haven't stopped at engine bay, my plan was to delete the box under the dash as well but keep the blower motor and heater functioning....and maintain a working digital climate control (well minus the cooling bit.)
The only way i could find to do this originally was  to buy an N1 'AC box' and the manual climate control unit  (N1's came out with no AC) which believe it or not is expensive, difficult to get a hold of and means you need to get rid of the sweet climate control set up.
so instead i wasted a heap of time and came up with these;
Now as you can see it's missing the ducting part but i wanted to ensure i could sort the difficult part first before dealing with that, so after getting $$$$ quotes to 3D print parts i wasn't sure would even work I bit the bullet and bought this..
and after converting computer speak to printer speak and 16 hours of printing later, this;
turned into this;
image2.thumb.JPG.bd042c80c4531202591c77829ebb32d2.JPGimage1.thumb.JPG.629214133daac2562696f31cb8358a4b.JPG
thanks for looking, I will have more shortly as i'm looking to wrap these up within the next few weeks
  • Like 2
  • Thanks 1
https://www.sau.com.au/forums/topic/473097-r32-air-con-delete/
Haha it's like that... printing stuff for no other reason than you can! Printers are much more affordable than many think, mine was less than $500. Is it professional quality? No but it's certainly not terrible and a lot of what I use it for prototyping parts to be done by CNC which is expensive to redo!Considering I was getting quotes for 80-200 for each of these pieces and 2-4 week wait time it was worth it for me. If you are looking to get some stuff made mate pm me and I'll do my best to help out :)
  • Like 1
small update, did a bit more work on this last night. Sorted the vents to run between the 2 halves, they have a 70 mm ID and without the AC condenser/radiator in the way i dare say it won't restrict flow too dramatically. The heater side was a bit of a pain I had to make to sure there was enough clearance to get the electrical plug on and off but also wanted to keep the flow as direct as i can.... anyways pictures;
the rendering
new part attached (on the final part i will probably plastic weld it but for now glue works)
weather stripping to hopefully seal the edges
and finally test fitted, happy to say it clears!
Almost there... over the last few days i have had some issues with the printer... it has been running non stop for about 3 months now so isn't really a surprise but annoying none the less! the worst part was the issue generally showed up 6-8 hours into a print making it a huge waste of material and time when it happen.
I have however pulled it all apart and made a couple mods and happy to say it's printing better than ever now.
reprinted blower motor side;
and installed
the whole assembly currently;
last piece of the puzzle is the blower side vent which is printing as i write this... and potentially a clip to hold the blower side tight to the top of the blower motor which has no  factory mounting points and over 25 years of heat cycling and the weight of the AC box on it has warped a bit in my car
  • Like 1
Some terrible plastic welding later and that's majority of the assembly complete!IMG_5610.thumb.JPG.499f01d42d29226e2454d82e786acd7a.JPG
I have to wait till the ac ducting shows up to join the 2 halves but other than a few minor tweaks that should be it.
Both halves fit pretty well so I'm quietly confident with how low the air flow is through the system there won't be any leaks but assuming the ducting shows up this week hopefully next weekend I will be able to test fit it all on a friends gtr and give it a proper test... I already have 3 sets of these i need to make for friends so i may send to a professional to print assuming the prices aren't too bad.
then the next step.... the real reason i deleted this box... you will have to wait and see if you are interested ;)
  • Like 1
  • Thanks 1
all ready for a test run! AC ducting showed up today, i'm glad I went to the effort of directing the vents towards each other because it turns out the ducting is rather rigid and really would have struggled to bend it nicely into place other wise. hopefully this weekend i will have some good news.
So over the weekend I fitted this to a mates GTR for the test run, from this..
to this in about 30 minutes;
as you can see it frees up a substantial amount of room and saves a couple kg's in the process.
Best of all no air leaks! well nothing significant, while poking around under the dash it turns out almost every join in a 25 years vent system leak. I forgot to bring the clip i made to hold the blower side firmly to the blower motor which is where there seemed to be a small leak but was fixed by pressing on the area so have no doubt that the clip will fix that. some thicker weatherstripping wouldn't go astray but trying to find the OEM equivalent stuff has been a pain. Overall though happy with how it's worked out and performs!
Plan from here.... I have some new plastic on the way which has a higher transitional temperature ( when the plastic starts getting tacky) the current plastic is 55*c while this new stuff is 90*c... 55 really shouldn't be an issue but potentially a hot day in the sun might test that more than i would like. I have made a few tweaks just for sensor mounts on the inside so they don't just hang around in there and potentially rattle around with the blower on.
When that arrives I can start making the few copies i need to do for others, then finish up the second half of the project... but that is much more specific to my car anyways.
thanks for looking! If anyone is interested feel free to PM me, I may send to a professional if there is enough interest otherwise for the odd unit a can use my machine ( just takes 33 hrs to print the assembly)
  • 3 weeks later...
Would you sell them made? If so, how much?
Hi mate,
I've only just received the new plastic so been doing the test runs with that right now! Please send me a pm if you are interested and we can work something out.
Thanks,
Nic
Hi Guys,
little while without an update, spent the weekend at racewars so has boosted enthusiasm to get some work done on my car!
I has been having issues getting the new plastic to print well but i think i finally have it, printed it in clear so it was easy to see any issues and pleased to say it all looks pretty good.
added a few little revisions to tidy things up like the temperature probe;
and why i bothered making this whole thing..... because where the ac box used to be is now where my ecu and fuse box live! (sorry about the crappy mismatched pieces most were tests to get this new plastic printing properly).
let me know what you think,
thanks,
Nic
  • 2 years later...
Hey mate! I just came by this thread by googling as i am deleting my ac myself and didn’t know what stuff i could remove in the cooling box and how to close it of after removing the ac matrix. Would you be willing to share the model as i am located in belgium europe, would be kinda fat to ship a 3d printed part ?. Love your work!
  • 3 months later...
another step in the rb 3d printing world. could even use the design and print from a higher quality if you really wanted.  i have lots of 3d printing done for my car, it can be seen in my build thread and i must say you quality looks great for what you have there mate! nice work
    • Well, apparently they do fit, however this wont be a problem if not because the car will be stationary while i do the suspension work. I was just going to use the 16's to roll the old girl around if I needed to. I just need to get the E90 back on the road first. Yes! I'm a believer! 🙌 So, I contacted them because the site kinda sucks and I was really confused about what I'd need. They put together a package for me and because I was spraying all the seat surfaces and not doing spot fixes I decided not to send them a headrest to colour match, I just used their colour on file (and it was spot on).  I got some heavy duty cleaner, 1L of colour, a small bottle of dye hardener and a small bottle of the dye top coat. I also got a spray gun as I needed a larger nozzle than the gun I had and it was only $40 extra. From memory the total was ~$450 ish. Its not cheap but the result is awesome. They did add repair bits and pieces to the quote originally and the cost came down significantly when I said I didn't need any repair products. I did it over a weekend. The only issues I had were my own; I forgot to mix the hardener into the dye two coats but I had enough dye for 2 more coats with the hardener. I also just used up all the dye because why not and i rushed the last coat which gave me some runs. Thankfully the runs are under the headrests. The gun pattern wasn't great, very round and would have been better if it was a line. It made it a little tricky to get consistent coverage and I think having done the extra coats probably helped conceal any coverage issues. I contacted them again a few months later so I could get our X5 done (who the f**k thought white leather was a good idea for a family car?!) and they said they had some training to do in Sydney and I could get a reduced rate on the leather fix in the X5 if I let them demo their product on our car. So I agreed. When I took Bec in the E39 to pick it up, I showed them the job I'd done in my car and they were all (students included) really impressed. Note that they said the runs I created could be fixed easily at the time with a brush or an air compressor gun. So, now with the two cars done I can absolutely recommend Colourlock.  I'll take pics of both interiors and create a new thread.
    • Power is fed to the ECU when the ignition switch is switched to IGN, at terminal 58. That same wire also connects to the ECCS relay to provide both the coil power and the contact side. When the ECU sees power at 58 it switches 16 to earth, which pulls the ECCS relay on, which feeds main power into the ECU and also to a bunch of other things. None of this is directly involved in the fuel pump - it just has to happen first. The ECU will pull terminal 18 to earth when it wants the fuel pump to run. This allows the fuel pump relay to pull in, which switches power on into the rest of the fuel pump control equipment. The fuel pump control regulator is controlled from terminal 104 on the ECU and is switched high or low depending on whether the ECU thinks the pump needs to run high or low. (I don't know which way around that is, and it really doesn't matter right now). The fuel pump control reg is really just a resistor that controls how the power through the pump goes to earth. Either straight to earth, or via the resistor. This part doesn't matter much to us today. The power to the fuel pump relay comes from one of the switched wires from the IGN switch and fusebox that is not shown off to the left of this page. That power runs the fuel pump relay coil and a number of other engine peripherals. Those peripherals don't really matter. All that matters is that there should be power available at the relay when the key is in the right position. At least - I think it's switched. If it's not switched, then power will be there all the time. Either way, if you don't have power there when you need it (ie, key on) then it won't work. The input-output switching side of the relay gains its power from a line similar (but not the same as) the one that feeds the ECU. SO I presume that is switched. Again, if there is not power there when you need it, then you have to look upstream. And... the upshot of all that? There is no "ground" at the fuel pump relay. Where you say: and say that pin 1 Black/Pink is ground, that is not true. The ECU trigger is AF73, is black/pink, and is the "ground". When the ECU says it is. The Blue/White wire is the "constant" 12V to power the relay's coil. And when I say "constant", I mean it may well only be on when the key is on. As I said above. So, when the ECU says not to be running the pump (which is any time after about 3s of switching on, with no crank signal or engine speed yet), then you should see 12V at both 1 and 2. Because the 12V will be all the way up to the ECU terminal 18, waiting to be switched to ground. When the ECU switches the fuel pump on, then AF73 should go to ~0V, having been switched to ground and the voltage drop now occurring over the relay coil. 3 & 5 are easy. 5 is the other "constant" 12V, that may or may not be constant but will very much want to be there when the key is on. Same as above. 3 goes to the pump. There should never be 12V visible at 3 unless the relay is pulled in. As to where the immobiliser might have been spliced into all this.... It will either have to be on wire AF70 or AF71, whichever is most accessible near the alarm. Given that all those wires run from the engine bay fusebox or the ECU, via the driver's area to the rear of the car, it could really be either. AF70 will be the same colour from the appropriate fuse all the way to the pump. If it has been cut and is dangling, you should be able to see that  in that area somewhere. Same with AF71.   You really should be able to force the pump to run. Just jump 12V onto AF72 and it should go. That will prove that the pump itself is willing to go along with you when you sort out the upstream. You really should be able to force the fuel pump relay on. Just short AF73 to earth when the key is on. If the pump runs, then the relay is fine, and all the power up to both inputs on the relay is fine. If it doesn't run (and given that you checked the relay itself actually works) then one or both of AF70 and AF71 are not bringing power to the game.
    • @PranK can you elaborate further on the Colorlock Dye? The website has a lot of options. I'm sure you've done all the research. I have old genuine leather seats that I have bought various refurbing creams and such, but never a dye. Any info on how long it lasts? Does it wash out? Is it a hassle? What product do I actually need? Am I just buying this kit and following the steps the page advises or something else? https://www.colourlockaustralia.com.au/colourlock-leather-repair-kit-dye.html
    • These going to fit over the big brakes? I'd be reeeeeeeeaaaall hesitant to believe so.
    • The leather work properly stunned me. Again, I am thankful that the leather was in such good condition. I'm not sure what the indent is at the top of the passenger seat. Like somebody was sitting in it with a golf ball between their shoulders. The wheels are more grey than silver now and missing a lot of gloss.  Here's one with nice silver wheels.
