57 minutes ago, Sovereign337 said:
If you haven't previously held a license, what do you guys recommend? AASA or L2S?
Shane!!!! L2S will be a little dearer, but it'll cover you for more events. On top of that, CAMS licences are accpeted by AASA, but its not necessarily the same for AASA licences at CAMS event.... @crashdown will need to confirm....
  • Like 1
Ladies and Gentlemen,
As part of each member's entry to SAU NSW's GP Track Day, Heasman Steering will be hosting a tech night on corner-weighing, shock rate design, and suspension set up for the track.
There are limited spots available, with 10 dedicated spots for members, in particular those who've entered GP. We'll be posting up a separate thread on the tech night to open it up to all members, but for now, for those who've entered GP, please let us know if you're keen on the tech night also.
Final details will be shared in the members thread in the coming days, but it will be held on one of the thursdays leading up to the track day.
First in, first served!
  • Like 1
I would be interested in attending
So to be clear, does that mean that the 1 day CAMS license is no longer available?
Got a couple of mates who are keen for the trackday but not so keen at having to buy the yearly license from CAMS.
I'll need to find that out for you, from the club executive in charge of that department. I will follow that up and get back to you with a reply.
We can supply a day licence.
Could you please let us know how many you would require (even if it is a max amount) before this Friday 20/4.
This is because we need to ensure we have enough available.
Thanks for following up.
Max would be 5.
I've got 3 definite and 2 tentatives
Max would be 5.
I will have 5 put to the side.
When they pay for their entry, let me know and I'll then allocate a day licence to each name. That way the sign on desk, will know on the day.
Greetings guys, not sure what the go is as its been a millenium since I've set foot near a track in a car.
Can someone please give me No.26 and link this forum name to my member number as I thought it would have been deleted soI left it off lol.
Much thanks Easto
  • Like 1
    • Hi guys . Can someone help me  I bought an Android screen for my Nissan fuga but it won't turn on
    • My guesstimate, with no real numbers to back it up, is it won't effect it greatly at all.its not a huge change in position, and I can't see the air flow changing from in turbulence that much based on distance, and what's in front of it. Johnny and Brad may have some more numbers to share from experience though.
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
