Hi all
I'm currently looking for a pair of tail lights for a R32 2 door, preferably with factory dark blue (paint code TH1) surrounds. I would also be interested in purchasing just the covers if anyone is just selling those.
I'm also looking for a 2 door boot lid. Not worried about colour but would be a bonus if it had no holes in it.
I'm located in ACT but happy to pay postage or travel if you're closeish
Thanks,
Nic
  • Like 1
https://www.sau.com.au/forums/topic/473364-wtb-r32-2-door-tail-lights-boot-lid/
If you are looking at painting the boot lid, I have a carbon one where the resin has fractures all through the surface. Could sand it back and paint it what ever colour you like. Has no holes.
Also has a carbon N1 boot lip on it in perfect condition, held on with sikaflex.
Also has a genuine R35 GTR boot badge.
$500 pick up from Wollongong.
This is it on my car. Cant really see the fractures through the resin with this pic, but the boot is covered in them. Ill have to see if i can get a better pic for you.
  • Like 1
    • New CAS just turned up from NZ Wiring. Looks like a nice bit of gear.  So, yeah. Triggered, bro. Realised I may as well do the cam belt while mucking about with it so will order one of them.
