Hello Guys
I have had a issue with my V36 350gt Sedan radio screen has switched off and now i don't have the radio working and can't change the air-con .
The Car runs fine but no way of using the entertainment unit which is also connected to the aircon .
First i thought maybe the screen/monitor or the switches or the radio control box . i brought all three and replaced them and still no success .
The next step was i have taken it to my mechanic but he specializes  in European cars so all he could do for me was to advise me of the error code.
BCM - DTC B2611 - ACC RELAY
I'm hoping one of you might be able to help find this relay and advise on how to replace it.
Cheers Pac.
Edited by Pac
reword
https://www.sau.com.au/forums/topic/473507-v36-350gt-air-con-radio-not-working/
Thanks for the help guys , i'll pass on the details when i get it checked out but it would be good know if anyone does know exactly where i can find this ACC relay. the G35 stuff kind of shows where it but i think it doesn't match the Japanese models.
Its been a while since i have been on SAU  and one thing that still strong with the group and helping each other out.
Had a look at that , there is a fuse box there so i'll look at it in more detail today  , but being that the infinity have the steering wheel on the other side i'm guessing it would be on the passenger side of the car.
Not necessarily. Wiring harnesses typically come in LHD and RHD flavours, so it's still very likely that those relays and fuses will be on the driver's side in your vehicle, as they are in mine when compared against the US G37 workshop manual.
  • Thanks 1
Finally !! I found the Relay , right where you guys said it was but it wasn't in plain sight , the relays are attached to the back of the fuse unit .
Just in case someone else has this issue here a picture , now the next step to to find a replacement relay and lets hope that fixes it if not then its gonna be some work replacing the cable.
Thank you all for the help.
  • Like 1
Exactly what Ben suggested. Swap with another one that's known to be working and see if it kicks in. Just don't pick a relay that disables anything else that the AV+A/C system would rely on, in accordance with the workshop manual.
If you know someone with access to a multimeter, just check the relay coil to be sure it's still in good working order (compared to another relay) and if it passes the resistance test, then feed the relay coil with a 12V power supply and check continuity between the contactors, as indicated on the diagram that's engraved into the relay. That way, you won't be wasting money on an expensive Nissan relay.
  • Thanks 1
Great success! well not great but good , the radio, Bluetooth and screen have powered up but still nothing from front panel aircon and controls , but the steering wheel controls are working .
Edited by Pac
Great News ! i got the aircon controls up now , i brought a spare air con control unit cover just in case if that unit was faulty just replaced it and everything is back online.
Thanks to all you  SAU members for the help .
  • Like 1
Worth a thought , but i'm too old to be doing that , back in my r34 days yeah but in the v36 i'm not sure if it suits it.
Edited by Pac
    • Scenic roads, stunning skylines, and Chickos to finish it off! Join SAU NSW as we cruise through the Royal National Park and along Lawrence Hargrave Drive to Figtree! Sunday 26th October 2025 4:30PM Meeting Waterfall Station Parking 5:00PM Cruise Departure Royal National Park > Lawrence Hargrave Dr > Memorial Dr > Sid Parrish Park 6:15PM Arrival at Sid Parrish Park Figtree Meet Location: Waterfall Station Parking Final Destination: Sid Parrish Park RSVP: https://forms.gle/E4s5SiRKQfDdypky8 *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • It's funny, as Ive seen plenty of people use them in cheap builds on YT. And they actually go okay, even though a lot of other maxspeedingrods stuff is terrible. Those turbos seem reliable enough, the only part being, a good quality turbo that is "identical" to it, will out perform it day in and day out. In both a lower boost threshold, and the ability to flow more air at the same boost pressure. As a cheap cheap replacement, not a terrible choice. For cheap and shouldn't blow in a day, not terrible (like other eBay/Temu turbos) for low cost and still decent performance, that's where the question comes in to play from the results I've seen. I'd actually find it hilarious to buy one, and strap it to a paddock basher or some other cheap as POS originally NA car, and send it to the moon!
    • The maxpeedingrods turbo is cheap and bolts on to stock parts. I think you just need a bigger silicone coupler for the intake. Its a cheap china turbo, but it's been running on mine for almost 3 years at 16-19 psi.
    • What do they look like right after you've tried to start it with everything connected? Also post photos of what they actually look like.
    • Also wanted to say, my new spark plugs are blackened looks like it's very rich. I have splitfire coilpacks but stock coilpack loom and ignitor. I tried directly grounding the ignitor ground to body as well.
