Hi guys,
In need of some expert/experienced opinions, It's a 1990 r32 gts4 that I purchased, I have liked skylines for a long time now and decided it was time to buy one, I was in over my head when I purchased this. What should I do? I've been offered 1k for it, i think i might try to get him up a bit but it won't get anything past 2k on a good day. Passion has gone and no where permanent to store it until I can give a shit again. It's killed my enthusiasm for cool/fast cars.
Problems:
  • no driveline
  • no interior
  • no diff
  • full respray would be needed
  • rust piece near rear window
  • Has a piece of metal overlapping a part of the frame which looks dodgy
  • paid too much for it, needs almost everything replaced
If I do get another skyline I'll be hunting for a perfect condition one from a SAU member. Pics attached.
xIMG_20180424_122846.thumb.jpg.15fe1b29efdaffe564b7732cefb6bb56.jpg.pagespeed.ic.hcpkYwkOWe.jpg
https://www.sau.com.au/forums/topic/473884-should-i-save-it-or-move-on/
You've answered your own question. The love has gone - just cut your losses and don't buy another car until you can afford one that doesn't require a fortune to fix ...in fact do you really want a project or do you just want a car you can drive?
  • Like 1
You sound like you've made up your mind. I'd push it and see how much this guy will give you for it but if you're burnt out now I'd just move it on.
If it was a GTR Shell then I'd possibly consider storing and keeping it till you're motivated due to the value simply getting out of control but not a GTS4 - Time to make it someone else's problem tbh.
+1
57 minutes ago, mlracing said:
Junk it, what happened to the rear guards lol
Someone widened them, idk why. It looks worse in person, ruins the lines of the car.
It seems like way too much work even as is, i've been offered 1250 for it and i took it because it needs a lot of work and the bloke who's bought it owns GTRs so he should be able to get it fixed and on the road/track again. He will take me for a drive in it when hes got it up and running so thats a plus for me if he remembers. But after you saying the 34 is nicer/newer i'll probably aim for a clean 34 tbh.
I was looking for an easy project but I was in over my head after really thinking about it, i'll be aiming for a driving car that's stock or close to stock next time, I really wanted a car thats clean, stock and runs well that I can throw mods at instead of repairs.
  • 2 months later...
Agreed. If the passion still there for this kind of car, then make it as a project. But you have some hesitation as due to the condition needed to work in the car, then i must say... move on as the passion is not the same. :)
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
