On ‎27‎/‎04‎/‎2018 at 9:57 AM, Frostyr33 said:
I hope mr miagi will be there with the nur skylines
2018 GT-R FESTIVAL - SATURDAY MAY 26th - SYDNEY DRAGWAY
The GT-R Festival is an event celebrating all things GT-R. Old school, R32, R33, R34 and R35 models all welcome to display and race. Activities will include drag racing, display ares for each model with multiple show and shine categories and trophies, GT-R heritage display, trade stands, motorkhana, Motive DVD GT-R Showcase, Ultimate GT-R Competition and more! New for this year is the Nismo display area, where non-GT-Rs can display their performance Nissans. For full info and schedule click here: http://motivedvd.com/motive/gt-r-festival/
  • 1 year later...
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
