Selling my Nissan Skyline R33 GTST 1994. I regretfully am looking at selling the car as I just do not get the time to drive it as much as it should be driven, as well as been given a work vehicle.
Details are as follows:
Engine/ECU/Control
-Built RB25 (have receipts for work)
 *Forged CP pistons
 *ACL race bearings - conrods
 *ACL race bearings - mains
 *Nismo Ring Set
 *Trust oil pump
 *Tomei Metal Head Gasket
 *Nismo Engine Gasket set
 *6L Race Sump
 *RB26 Rods
-Haltech platinum pro
-Haltech 4 bar map sensor
-Haltech air temp sensor
-AFR Wideband Kit with Gauge
-Flex Sensor
-150psi oil pressure sensor
-150psi fuel pressure sensor
Turbo/Intake
-GT3080 with 0.82 housing
-T3 manifold
-PTP Turbo Blankets - TURBO BLANKET LAVA
-40mm turbosmart wastegate
-Turbosmart kompact blow off valve
-Plazmaman plenum
-Plazmaman fuel rail
-Plazmaman piping
-Large frontmount
-Turbosmart E-Boost 2 controller
-Oil cooler
-PWR radiator
Fuel System:
-Turbosmart Fuel Regulator
-1700x ID injectors
-Spitfire coil packs
-Custom catch can
-Radium surge tank in boot with 2x walbro 450 fuel pumps with 50amp relays and wiring
-All black teflon braided lines
Suspension/Drivetrain:
-NPC twin plate clutch
-Rb25 gearbox
-Hardrace camber and toe arms
-Hardrace traction rods
-Full HICAS eliminator kit (not lockout bar)
-BC racing coilovers
-Evo big brembo brake rotors caliper setup fronts
-345mm Rotors front
-R33 gtst standard rear calipers
-DBA slotted rotors
-Pumped guards
Wheels:
-Discontinued BuddyClub wheels powdercoated black 15x8 +32 5x114.3 x2 (drag setup with Mickey Thompson Et Street R tyres)
-Work Meister S1R 5x114.3
    Matte Black with polished black lip.
    Front: 18x9 + 22 = Nitto invo 225/40
    Rear:  18x10 + 30 = Achilles ATR sport 265/35
Other:
-Tuned by DVS Jez to make 330kW on 25psi on his hub dyno
-LETZGO plates included
-Carbon Fibre bonnet colour matched
-Rego till 29/10/18 (5+ months)
-Ran 11.8 @ 124
Negatives:
-Front left wheel has a slight bend (does not effect anything), right left wheel has gutter rash
-Gearbox crunches into 4th at high speed.
-Car requires an amp to rewire speakers to (removed as wanted nothing in boot).
Car has been maintained with the best parts and always serviced on time.
Has had the following done 1000 km ago:
-New oil
-New oil filter
-New NGK spark plugs
-Full system coolant flush
-Gearbox oil (hardline shockproof)
-Diff oil (hardline shockproof)
No test drives without deposit, no time wasters will be tolerated.
Can bring your own wheels for a cheaper sale price.
Price is $19,000 with both wheel setups.
https://www.sau.com.au/forums/topic/474014-r33-gtst-330kw/
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
