Hi guys, just thought I would put up some pics of a fun project I am building. It is a exoskeleton-type chassis that will seat two and is mid-engined. The chassis is not yet complete in the photos, and I am busy adding triangulation and making changes as I go. Won't be using STI wheels, those were just for "full effect" ?
For now this is being built in mild steel as-is a prototype that needs changes made as issues arise during manufacture. Once i am happy with the final specifics and approved for road use, I will build another from much thinner wall 4130 chromoly. I am a Fabricator, so the welding shots were compulsory!
This car is running an Alfa Romeo 2.0 engine, which I have also developed a turbocharger setup for, and will make between 250-350hp boost-dependant. This will weigh about 550-580kg. I also have a 370z engine that I may twin-turbo and throw in the back, which would be quite hilarious.
Depending on my workload, I hope to have this thing running in the next few months, and if there is any interest I will keep it updated as things move along. Hope to do some roll racing and circuit racing in the future at SMSP and Wakefield
  • Like 2
https://www.sau.com.au/forums/topic/474167-custom-tubeframe-ghetto-beast/
1 hour ago, Leroy Peterson said:
Very nice.
What transaxle do you plan to use? Looks pretty tight in the back
There is plenty of room for transversal setups. The current engine as mentioned is Alfa Romeo using a FWD gearbox. When I do the next chassis with the VQ37 I will use a Maxima manual FWD gearbox and shafts, at least that is what I am planning
Do you know if the RWD VQs will happily bolt to the FWD VQ gearboxen?
I was going to ask "since when has there ever been a VQ powered manual Maxima?" and then I looked on Wiki and was surprised to see that Nissan actually made some.  Seems totally out of character/market segment for a Maxima though.  I wonder how many are actually out there in the wild?
To be honest I would assume there would be some adaptation necessary, however the standard VQ bolt pattern should carry over without issues, then the "fun" would begin to make it all work. I feel the gearbox itself would be quite robust, as it is designed for the VQ engine and to carry a big car that would potentially be full of passengers and a big trailer hanging off the back. No idea how many were produced, but I will be beginning a search in the near future
So I decided that the Alfa Romeo engine would be better served in my Formula 3 (as it was an engine originally used in the series) and have decided to install a Lexus 4GR-FSE engine, stroked to 3.5L and using a single turbo setup. The second chassis I make will probably be intended to look a lot more like the Ariel Atom and that will use the VQ37 engine that I have stored away.
I advanced with one of the manifolds today, using a narrow angle configuration for the runners, which will promote scavenging. The two banks of manifolds will merge together and the turbo will sit above the transmission.
    • I downloaded the apps (for windows) and Consult 1 doesn't have this function on it for the Consult 1 plug which I'm pretty sure all Skylines have. You would think someone would have a workaround after 30 years for all Skylines which have ABS.
    • Also, I don't know the actual ABS system on the skylines, but a sneaky thing could be a piece of electronic equipment that makes the ABS think you're moving, and then same piece can send a signal for a locked up tyre... Activate ABS without slamming brakes...
    • The team at OBD2 Australia are pretty good, shoot them an email and ask them. I've dealt with them before for work stuff. I'd be shocked if it didn't work, so long as Consult can activate the ABS. But you might need to use KLine for it which would be the stopper, as I don't think that piece does KLine comms.
    • Yeah and hence my ghetto way of slamming the brakes, get the ABS to cycle, rebleed seems to be a sensible workaround.
    • Hey! Happy to help. Nothing inherently wrong with the adapter, it's more so with Brett Collins himself. He gave me a lot of incorrect information when I was in contact with him and was extremely rude when I challenged him. He stated I could not use any aftermarket twin plate clutches except for his own, not to use the dush shield, bla bla bla and it was all BS.  Collins stated to cut roughly 14mm's off the housing, I took off 15mm to make room for the dust shield. I would confirm with whatever adapter manufacturer you're using.
