Recently got an alignment for my R32 GTR, all still within spec except left rear camber.  Still riding on old factory upper control arm, and the eccentric bolt is maxed out.  They told me a new bushing will not make up enough of the 0.5 degree difference even if I get new OEM upper control arm.  Is that a fair statement?  How about the Nismo upper control arms?  All the adjustable aftermarket options I find all use solid bushing, but I still want to use tradition rubber bushing, is there no such aftermarket option?
https://www.sau.com.au/forums/topic/474192-r32-rear-upper-control-arm-options/
I guess you are trying to stay within factory settings; have you also got the factory suspension?
If so, most likely the car is riding lower than it used to which gives more camber, you can measure the distance from the centre of the wheel to the rear guard on both sides to see if it is even. New springs may be a good idea.
The other, less likely, possibility is that something has been bent over the years. In that case a new, factory arm would probably correct it if you knew exactly what was bent out of upper control arm, traction arm, lower control arm, hub, toe/hicas link, subframe or subframe mounting point.
Thank you all for the information.  Yes I would just like to get back to factory spec, no setup for track or anything else.
My car came with Nismo S-tune coilover, which only lowers 10mm so should not be a big issue for camber.  Front components are all Nismo, but but rear control arms are still factory, so they are 28 years old now.  Given how old the rear arms are, I thought just getting new ones would fix the camber, but my alignment guy had doubts because of how little adjustment the eccentric bolt can do.
I have never heard of Hardrace, they seem to offer a good range of products, but trying to buy them in the US appears to be a pain.  I think I will go with Whiteline.  Even though Whiteline only labels their upper controls arm to fit S13 and Z32, they are identical to R32 correct?
Just realize Whiteline uses polyurethane bushings instead of rubber.  Not a fan of polyurethane, so I will try to source a pair of Hardrace.  However, I found this brand I never heard of called TruHart also makes one for 2/3 the price.  Have you guys heard of it?
http://www.truhartusa.com/Rear_Upper_Control_Arms_for_89_94_240sx_Skyline_p/th-n201.htm
19 hours ago, niZmO_Man said:
Looks like stuff off ebay.
Perhaps contact these people:
www.buyhardrace.com/
Yeah I emailed and called them Monday morning, no response until now.  $200 USD plus shipping and a 1-2 month wait...
I had bad experience with polyurethane bushings, but if I don't want to get those eBay junk then looks like Whiteline is the only option left. $160 USD shipped through Amazon, so actually not a bad deal.
I have early, limited run GKTech ones in my car, they haven't made a sound in 4 years, but the cheapo red ones from JustJap (I'd say same as the cheap eBay arms) squeaked after about two months of daily driving. Price IIRC was about $150-ish AUD per pair for the arms, so $160 USD for Whiteline seems reasonable.
    • Who did you have do the installation? I actually know someone who is VERY familiar with the AVS gear. The main point of contact though would be your installer.   Where are you based in NZ?
    • Look, realistically, those are some fairly chunky connectors and wires so it is a reasonably fair bet that that loom was involved in the redirection of the fuel pump and/or ECU/ignition power for the immobiliser. It's also fair to be that the new immobiliser is essentially the same thing as the old one, and so it probably needs the same stuff done to make it do what it has to do. Given that you are talking about a car that no-one else here is familiar with (I mean your exact car) and an alarm that I've never heard of before and so probably not many others are familiar with, and that some wire monkey has been messing with it out of our sight, it seems reasonable that the wire monkey should be fixing this.
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
