hey guys im currently looking at buying a new turbo for my stagea kinda wanna buy it tonight so i can be ready for the all jap day coming up
what is the standard turbo flange size?
what is a good replacement turbo?
what are some good coils? spitfire?
what else should i be replacing? it has 100tho ks already had timing belt and water pump done
im going to replace the crack sensor, the sensor on the air intake (o2 sensor ?)
and anything else that i need to do
thanks guys
https://www.sau.com.au/forums/topic/474393-c34-stagea/
Why are you replacing the turbo at 100,000km (if that's genuine km)? If you want a bigger turbo you have to also look at intercooler, exhaust, injectors, fuel pump etc and of course an aftermarket ECU or a Nistune chip. The only coils I would suggest are OEM or Splitfires - and of course plugs while you are there.
The crank sensor is unlikely to need replacement nor is the sensor on the air intake (MAF sensor) but by all means replace the O2 sensor on the exhaust downpipe.
There is heaps of information in the Stagea (wagoneers) section especially in the DIY section.
https://www.sau.com.au/forums/topic/102808-stagea-d-i-ys-how-tos-f-y-is/
https://www.sau.com.au/forums/topic/474393-c34-stagea/#findComment-7879835
Well if you are after a stock replacement it depends where you are - good idea to put your city and country at least in your profile. Most popular replacement that you can run with stock ecu etc is one from Hypergear (look up his thread and give him a phone).
https://www.sau.com.au/forums/topic/474393-c34-stagea/#findComment-7879844
Check the turbo for shaft play first. If that is OK, just fix the leak. If you want to go replacing the turbo, you'll be finding you need to do quite a few other things as well to make it worth it: exhaust, valve body upgrade if an auto car, FMIC, and tuning.
If you need to swap turbos without the supporting modifications, Id ask about turbos smaller than the 21U hypergear high flow unit. That will keep the engine response and power curve close to stock - something that is an important consideration for a daily driven, heavy vehicle.
https://www.sau.com.au/forums/topic/474393-c34-stagea/#findComment-7880320
Yeh cool cool thanks for the information guys there is a few things that need to be done rocker cover seal need to figure out why its burning spark plugs as well something I really need to figure out I'm pulling the turbo off this weekend also the car is badged as a 2.8l and has a his 2.8l mod plate under the hood with a hks front mount what's the best way to tell if it is the 2.8 or not when I get it alsort I want to spend money on it and take it to next level I want around 300kw and yes I know I need to pay to play
https://www.sau.com.au/forums/topic/474393-c34-stagea/#findComment-7880394
Well I know hks do a 2.8l strocker its got the plate from khs under the hood saying it's a 2.8 with the engine builders name with 2.8l badges all over it probably got taken out before it come over and yeh I'm 99% certain its stock turbo seams like stock ecu a well so that points out it's not
https://www.sau.com.au/forums/topic/474393-c34-stagea/#findComment-7880397
Turbo is definitely leaking and has heeps of play in it I'm not going back to stock here is what I'm looking at
6boost manifold twinscroll
GTX 3076R GEN 2 (not sure what housings to get or if x2 waste gates is necessary )
225 walbro fuel pump
550cc injectors
Spitfire coils
Trans cooker
Looking at haltech ecu or nistune
forward facing plenum
Pwr radiator
Its automatic and its staying that way so I know I need to keep the power around 280kw and even then I'll probably kill it so what auto trans options do I have other then a rebuilding the current 1 any 1 put a 5 speed or 6 speed auto out of something elce onto a rb25?
Edited by zal
https://www.sau.com.au/forums/topic/474393-c34-stagea/#findComment-7880479
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
