The motor is an Rb25de from an R34. I noticed my tps voltage was .20 closed. I adjusted it to oem specs at 4.5 or so and that's when I started getting the high adle around 1300-1500. If I unplug the aac the idle goes back to normal. If I set any values on the aac in consult the idle goes back to normal. I thought I may have a bad tps and installed a new unit but the same thing. The aac adjustment screw is all the way down (and broken so I cant back it out again). I've cleaned it out a while back but never had an issue until now. Not sure why my idle is screwed now because I touched the tps..
Edited by ~KnuckleDuster~
https://www.sau.com.au/forums/topic/474489-high-idle-after-tps-adjustment-r34/
Anyone? If I'm a dummy feel free to let me know. Iv'e attempted to set the base idle per the write ups, I lowered the tps closed voltage back to where it was at .2 and still high. Cleared the ecu memory. Not sure if there's another song and dance I need to perform to have the new tps setting dialed in or if the next step would be to open up the aac and inspect that.
The R34 also has a manual throttle stop bolt, I always found that adjusting that was easier than the screw in the side of the AAC itself which appears to be made out of something with the strength of warm butter.
I had many R34 AAC's fail in general to the point where I bypassed it with a BMW unit lol
The timing was around 17* last I checked when the idle was low enough. The throttle stop bolt is backed out all the way.
The black plastic adjustment screw which was broken off was at least tightened all the way down which is the lowest point for the idle to be at but the idle was still at 1300. I chipped out the broken screw and put in a medal adjustment screw from an rb26. Now the idle is at 2k. If I unplug the aac the idle is still high around 1100-1200. I just don't get why adjusting the tps from .2 to .4 has f'ed this whole thing up!
Worst part is I'm in the US and finding an AAC from a DE is insanely difficult.
How sure are you that you don't have a leak? What happens if you block off the hose going to the IACV?
In the end I hollowed out my R34 IACV entirely, and just ran another IACV in the hose that runs to it. Only going to really work if you have an aftermarket ECU that is controlling said IACV though.
Note: My 34 one failed and when it fails, it fails open. As above, no leaks, throttle stop bolt entirely out, idle of 2000RPM.
Why not just change TPS voltage when closed back to 0.2? I noticed in my car (again not completely the same) that voltage when car on but not running may have been 0.2, but I would find that 0% throttle with car running the voltage was different, perhaps 0.5 actually.
Pretty sure I don't have a leak, I have a full time vac gauge in the car. Ill see what happens when I block the hose off and run it today.
If I could get away with just bypassing this thing I will. I'll do that as a last resort. I put the tps back to 0.2 and the idle was still 1500. Used to idle around 750-850 prior to me touching the tps.
I'm using the consult port and running datascan software so I can select values on the aac. If I put it anywhere from 1-9 the idle drops down. So it's as if the aac is just staying wide open unless manually told to do something different.
Ok so blocked off the vac to the aac and started it up. Still revs to 2k but will hunt from 1300 to 2k. With the vac blocked and aac unplugged the car starts up fine and the idle is wavering around 1000, revs and sounds healthy.
Is that a sufficient enough way to bypass this thing? Is it ok to leave the coolant running through it?
The coolant should be left going through it as it is the high point bleeder on the whole circuit.
"Bypassing" is by just blocking off its air supply is a bit crude.  You own't have idle up for air-con or high electrical load.  But if it's already idling high, that's probably not going to stall you out.
I would try another ECU.
    • Haha, i kow right? Could have bought so many cars for the same amount of money (or less) but driving Unicorn gives you at least +1mln to style 😅. Like wise man said "life's to short to drink cheap wine and drive boring cars" 😉
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
