High Idle after Tps adjustment R34
The motor is an Rb25de from an R34. I noticed my tps voltage was .20 closed. I adjusted it to oem specs at 4.5 or so and that's when I started getting the high adle around 1300-1500. If I unplug the aac the idle goes back to normal. If I set any values on the aac in consult the idle goes back to normal. I thought I may have a bad tps and installed a new unit but the same thing. The aac adjustment screw is all the way down (and broken so I cant back it out again). I've cleaned it out a while back but never had an issue until now. Not sure why my idle is screwed now because I touched the tps..
Edited by ~KnuckleDuster~
Anyone? If I'm a dummy feel free to let me know. Iv'e attempted to set the base idle per the write ups, I lowered the tps closed voltage back to where it was at .2 and still high. Cleared the ecu memory. Not sure if there's another song and dance I need to perform to have the new tps setting dialed in or if the next step would be to open up the aac and inspect that.
The R34 also has a manual throttle stop bolt, I always found that adjusting that was easier than the screw in the side of the AAC itself which appears to be made out of something with the strength of warm butter.
I had many R34 AAC's fail in general to the point where I bypassed it with a BMW unit lol
The timing was around 17* last I checked when the idle was low enough. The throttle stop bolt is backed out all the way.
The black plastic adjustment screw which was broken off was at least tightened all the way down which is the lowest point for the idle to be at but the idle was still at 1300. I chipped out the broken screw and put in a medal adjustment screw from an rb26. Now the idle is at 2k. If I unplug the aac the idle is still high around 1100-1200. I just don't get why adjusting the tps from .2 to .4 has f'ed this whole thing up!
Worst part is I'm in the US and finding an AAC from a DE is insanely difficult.
How sure are you that you don't have a leak? What happens if you block off the hose going to the IACV?
In the end I hollowed out my R34 IACV entirely, and just ran another IACV in the hose that runs to it. Only going to really work if you have an aftermarket ECU that is controlling said IACV though.
Note: My 34 one failed and when it fails, it fails open. As above, no leaks, throttle stop bolt entirely out, idle of 2000RPM.
Why not just change TPS voltage when closed back to 0.2? I noticed in my car (again not completely the same) that voltage when car on but not running may have been 0.2, but I would find that 0% throttle with car running the voltage was different, perhaps 0.5 actually.
Pretty sure I don't have a leak, I have a full time vac gauge in the car. Ill see what happens when I block the hose off and run it today.
If I could get away with just bypassing this thing I will. I'll do that as a last resort. I put the tps back to 0.2 and the idle was still 1500. Used to idle around 750-850 prior to me touching the tps.
I'm using the consult port and running datascan software so I can select values on the aac. If I put it anywhere from 1-9 the idle drops down. So it's as if the aac is just staying wide open unless manually told to do something different.
Ok so blocked off the vac to the aac and started it up. Still revs to 2k but will hunt from 1300 to 2k. With the vac blocked and aac unplugged the car starts up fine and the idle is wavering around 1000, revs and sounds healthy.
Is that a sufficient enough way to bypass this thing? Is it ok to leave the coolant running through it?
The coolant should be left going through it as it is the high point bleeder on the whole circuit.
"Bypassing" is by just blocking off its air supply is a bit crude.  You own't have idle up for air-con or high electrical load.  But if it's already idling high, that's probably not going to stall you out.
I would try another ECU.
 Share
    • I'll bite. I no longer own any euro's, but I thought I'd share two of my favorites I owned. My 500hp B5 S4 and my 800HP E55 AMG. Yes I did attempt to drive the E55 in Canadian winters, that lasted all of a month as it was a death trap.
    • To be fair this is the wife’s car. However, I have been accused of owning more cars than I have pairs of undies. Luckily I change my undies more frequently than the cars.
    • Cheers Lads Looking at changing up a few things maybe go 2.8lt, bigger injectors with more a modern Turbo. Possibly transbrake and convert to E85 with Haltech ECU. Any thoughts on those Mods changes or better ideas? Want to try keep the car Street/Strip While also being weekend drivable still.
    • The time has come, once again, for us to celebrate all things GTR! Motive DVD's GT-R FESTIVAL for 2024 is fast approaching, and we couldn't be more excited to be part of this awesome event once again! As usual, SAU NSW will be be part of the event, with our traditional club display on the day! If you would like to be part of it, firstly, you'll need to make sure you secure your Display Entry into the show via the below link by Motive Video: https://gtrfestival.com.au/ Other tickets are also available, ie. VIP Entry or Drag Entry, for you to also choose from. Once you have your ticket locked in, make sure to send us a PM via Facebook so we can add you to our list of display cars! When you message us, we will gather some more details from you to make sure we can spot you on the day, and guide you to the right place! If you'd like more information regarding the day, please refer to Motive Video's event page, or, you can get in touch with us and we will help you as best as we can. As always, general details are below: Date: Friday 24th May / Saturday 25th May Location: Sydney Dragway Time: 6.00pm Friday / 9.00am Saturday We look forward to seeing you all on the day! One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAUNSW and thus, treat others accordingly. • Any misbehaviour will not be tolerated and you will be asked to leave. Thanks guys and hope to see you there!
