5 minutes ago, GTSBoy said:
So long as the tuner is able to do the board install (it's not just plug and play, there are cleaning and soldering tasks to do) and has the Consult cable and software....the answer  is no.
I have a local guy here (state side) who is a tuning guru and I’m gonna give him a ring this week.
Guru or not you are not going to get an extra 100KW with those "mods". You will at least need to set your boost to 10 to get a noticeable increase. Front mount and better exhaust will help...
4 minutes ago, GTSBoy said:
It will be in the order of 10rwkW unless you add boost.  But, if tuned well, it will feel a lot faster than that because more timing and less fuel in the middle of the maps will sharpen it up a lot.
I was thinking along the same lines as well. I heard the factory tune on these is a bit rich?
19 minutes ago, SeanR32GtSt said:
I can definitely feel the fuel being too much in the mid to higher rpm range. Does having a VTA blow off valve have a negative effect on that as well.
Nope.  Only time that matters is when you lift off with boost and the air gets let out, leaving the engine overfuelled for the next few seconds.  Under boost, the BOV is closed, so the mixtures should be what the AFM&ECU say they should be.
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
