Hi guys,
I just noticed my R33 GTR front door trims are starting to show its age and shows some rips so it's time for me to do something that I've always wanted to try which is to wrap them in carbon fiber. Has anyone done this and how hard was it? Which time of wrap did you use and how long did it take?
Also, does the wrap come with adhesive or will have I to spray it with adhesive glue?
Any photos would be great!
Image result for r33 gtr carbon fiber door card
Edited by Robocop2310
Sorry but that’s a terrible idea. It looks soo trashy.
Either find second hand replacements or if you are dead set on carbon try finding someone that makes inner door trims
7 hours ago, GTSBoy said:
It won't stay stuck to something that moves, like the padded vinyl that the door trims already are.  Will bubble and lift and....look trashy.  More trashy even than when it was fresh.
What you said is 100% spot on. I just spoke one of my friends who does vinyl wrapping on the side and he said the same.
I just came back from a Jap wrecker and bought used replacement trims ended up costing $250 for the pair but you're right better idea as wrapping is probably not an option.
Thanks for your reply - helpful as usual!
You're right mate. I thought about it and felt this would sacrileges to do especially toward a GTR so I ended up going to a local wrecker and buying replacement trims.
I guess for a 25 year old car the trims being worn is a given.
Thanks for your honest opinion.
  • 4 weeks later...
3 hours ago, CU's GTR said:
You can get carbon fibre dipping done. I have done it to the dash on the car. It looks friggin awesome.
The guy is in Ferntree fully and can get his details if you need it. Don't wrap it it will peel over time.
Sounds good. Post up some details and pictures if you can mate I'm sure many people will be interested.
http://melbournehydrographixdepot.com.au/
Thanks mate looks interesting.
Would you be kind enough to share a few photos of what you had CF dipped?
Below is a snap a similar item they did.
That isn't the case. The surfaces are dipped and a clear is.dprayed over the top.
They dip wheels and anything that is possible. If wheels can be dipped and driven without flaking so can most surfaces.
Ring this guys and he will tell you of it will work.
People will give opinions on something they dont know much about.
As for the steering wheel, I got this one off eBay. I was originally doing to get the steering done by ultimate auto trim. They do that as well and what every style and design you like.
However I found this on eBay and so I have the original steering wheel for the car. The original steering wheel is immaculate, so I would have been a shame to dedicate it. [emoji41]
Jump onto their website or eBay and it shows what they have done so far.
OK, here's an exercise for you.  Go dip a vinyl glove.  Let it dry.  Put it on.  Scrunch your fingers.  What do you think will happen to the dip?  Really?  What do you think will happen?
Wheels are rigid surfaces.  Door trims are NOT.  They are vinyl backed by polyurethane foam to give them the "soft touch" experience that people want.  If you want the tacky tacky experience of carbon fibre dipped door trims, tou would first have to remake the door trims out of something hard, like ally, or fibreglass.....or carbon fibre.
  • Like 1
All this is too hard so I ended up getting second hand door trims from a local wrecker for $300.
I must admit, door trims don't get seen very often so it doesn't matter too much what it looks like, I guess.
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
