I have done a fair bit of research on this topic, I just want to ask a few questions because it wasn't clear in the threads I read.
Basic options for a R33 is to:
  • Weld/Shim the VLSD (both making the diff 100% locked, the shims don't act the same way as they do in clutch type LSD as they space the spider gears closer together locking them up).
  • Swap R34/S15 helical diff centre into my R33 GTST housing, question being do the half shafts have the same spline as the 5x1? As I know the s15 have 3x2 half shafts.
  • Spend big dollars on a aftermarket locker, about $1800 at least. Is there any cheaper option, I've heard the ATS LSD diff is cheaper about $800 clutch type but can only find it for front diff on r33 gtr.
  • Swap 350z lsd diff in - Would the 5x1 v35 diff go straight in with the conversion spacers from gktech or do you need to change out the axles?
Is there any other options I am missing? I don't really want to spend $1800 on a aftermarket looker, I have a s15 helical lined up for $300 that looks to be in good condition. Not sure if r33 half shafts with fit s15 helical centre though. Is there much involved with fitting a 350z diff in with the axle shafts?
https://www.sau.com.au/forums/topic/475723-r33-skyline-diff-options/
I have fitted a S15 hlsd diff centre into my R34 vlsd, everything fits internally but as mentioned the S15 has 3x2 output shafts and the R34 viscous lsd 5x1 shafts do not fit. I had to buy new output shafts for a R34 helical diff which was fitted on later models for the 5x1 output shafts. I used the S15 crown and pinion gears as well for the 3.69 ratio so I had to re-shim to get the pre-load and backlash set correctly. In the end it all worked out but was costly and time consuming.
I would have thought the slightly taller final drive a bonus...does it suit your needs?
Why are you looking at changing the diff?
Nismo do a sweet 2way diff, 4.08 ratio and no stress, just take yours out and put the new one in and your done. Never have to worry about your diff again.
PS it even comes in ABS model
Edited by WR33KD
Can’t spell to save my life
On 1/8/2019 at 7:27 PM, steve200b said:
I have the 350z diff in my car the inner cv’s from the 350z will fit your r33 driveshafts. That way you get the 6x1 stub axels and the std vlsd has not pegged up at all.
That's cool.  I didn't know the CVs would transfer to the older shafts.  Opens up a whole world of possibilities.
14 minutes ago, iruvyouskyrine said:
The 350Z has 6x1 stub axles yeah? You would still need GTR 6x1 driveshafts though wouldn't you? Or am i confusing something here?
Yuh, you are confusing it/yourself.  I initially read Steve's post the same way you have.  Stop and read it again.  Imagine pulling the inner CV joint off your R3x axle and throwing it over your shoulder.  Do the same to a 350Z driveshaft but toss the shaft and keep the CV joint, and then jam the 350Z CV onto the end of the R3x axle shaft.  Et voila, you have gotten rid of a CV that has 5x1 bolts and replaced it with a CV that has 6x1 bolts, on the same axle shaft that you always had in the car.  Now this axle will connect to a diff that has 6x1 flanges.
  • Like 2
Is it 39654+A or 39600DA? This is relevant to my interests as i have a 350Z diff at home and was considering changing to a CD009 gearbox that i also have and R200's are hard to get in good ratios to suit the 6 speed.
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
