Hey guys, an update.. bad news kinda.
Well, seemed that there has been a fair bit of work needing attention on the engine (including a f***** new gasket!!). Thus the car would only be getting to Canberra mid-this week. Now, seeing as I'm taking a break and going up to the Gold Coast for Christmas (where the car currently is) I have decided that the cost and wear on the car is not worth bringing it down here for the time left before I'm on holiday.
Thus, the car will not be here till next year!! (When I do the return trip to Canberra). Dunno if I'm coming to Summernats, depends what the turn out of skylines and mates are gonna be there so we'll see. Anyways (sry bout the length of the post), I'm going early next week so look forward to seeing everyone next year and unveiling my car. I know I havn't made much of an appearance so far, but I'll change that next year :).
Good Luck to everyone over the new year. See you all soon
You're game putting a skyline in Summernats. usually the bogans don't like their presence. i was thinking of going in the sound off only, but basically i'd rather not get the car kicked in or keyed.
Yeah I was thinking that, xept I'm planning on going with my brother and another couple of mates... a rocket VN wagon and showy VT from the Gold Coast.
But yeah, proly won't end up hapnin, I care too much bout my car... still go c the show tho :D
  • 3 weeks later...
sounds nice :rofl: Stupid question though you say you have a 300zx turbo running 14psi would that not be making alot less power than a standard rb20 turbo ??? only reason i ask is i though all 300's were a 3L twin turbo thus each turbo is designed around a 1.5L engine ??? correct me if i am wrong
Leigh
Hi everyone!
First post.
1989 GTS-t 4 Door
3" Exhaust From the Turbo back
Fuel Pump
Suspension
300ZX Turbo running 14psi
Turbo timer and imobilizer with remote start.
Good sound system.
Pretty standard affair.
Only got it last week!
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
    • Ok, disregard my “rate them” comment, sorry for my unrealistic input
