im 16 and this is my baby!
3inch turbo back exhaust
12" sub
polk audio fronts& tweeters
kenwood head unit
had alpine r series in the rear but they had to be removed for the child restraints that had to be put in for rego
was lowered on king springs.. but was to low for rego
18" rims
pod filter
front mount intercooler
running stock boost atm
exc...
I am thinking about selling it tho im not sure how much to ask... what would you say it would be worth?post-127489-0-49230200-1384850202_thumb.jpg
12" sub
kenwood head unit
18" rims
pod filter
full auto turbo timer
was running 12psi
exc...
Hey guys, new here. Bought the car last thursday. Names Chris :)
1996 GTS25t Series II
HKS HiPower 3.5" Catback
HKS SSQV bov
18" Rota Grids staggered 19.5 & 18.5 with Federal Semi's
Generic Pod filter
Bleed valve pushing 10psi tops
That's my mates old car haha!
Mum thinks I'm to much of an idiot in it. Haha. I love it. Gets a bad amount of cop attention due to it fluttering :/
Change BOV quiet it up a bit. You will always get attention on your P's. Doesn't matter what car you drive.
Hi fellas, I'm new here.
Got my GTR r34 V-spec II few months ago.
A list of brief upgrades include:
2001GTR r34 V-Spec II
TOMEI RB -B Twin Turbos
Tomei Poncams
ARC Intercooler
SARD 800cc Injectors
NISMO Oil Cooler
ORC Clutch
KOYORAD Radiator
HKS Intake and full piping
HKS complete exhaust
Oil Catch Can
NISMO MFD Display Screen
NISMO Front Bar and Full Body Kit
TEIN Street Advance Coilover Suspensions
19" x 10" wheels with 275 x 35 x 19 tyres all round.
Tomei Poncams
ARC Intercooler
NISMO Oil Cooler
ORC Clutch
KOYORAD Radiator
Oil Catch Can
  • Like 1
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
