Please read description very carefully.
Carbon Kevlar and Billet Intake Plenum to suit RB25-DET-NEO motor.
All billet has been anodised satin black.
Plenum has a flange to suit a Drive By Wire (DBW) Bosch 82mm Throttle Body (not included). Brand new genuine throttle can be included for an additional $250 (RRP $350)
Includes a black billet fuel rail (no injectors included).
As far as I am aware the plenum will only fit a NEO. You will need to do your own research if it suits RB20 or RB25. (It will bolt on, but I am unsure about coolant journals matching up).
You will need to fabricate your own coolant lines from Speed Flow or similar. Merge collector for the coolant lines is included. ($250 value). Collector has a 4 x -8 female fittings to a single -20 female fitting on it.
Plenum cost $4000 to have made. It is unused. Blue tape is only to avoid scratching when trial fitting. The merge collector was an additional $250 on top of this.
$3600 with the merge collector $3850 if you need the throttle included as well.
Pick up from WA or will courier Australia wide for $60.
My bad, my apologies it's really been the week from hell. Was a cut and paste job from Scumtree
Edited by masTers
  • Like 1
Just added to the topic. ?
  • Like 1
Pics should be in the first post, I can see them fine. Do they not load for anyone else?
Cheers,
Steve
Pics aren't showing for some in the mobile app at the moment.
They can be seen in the web browser though.
  • Like 1
Am open to reasonable offers on the lot.
I am also open to a part swap of a pair of 33 GTR brembos plus cash my way.
Edited by masTers
  • 1 month later...
  • 1 month later...
  • 1 month later...
  • 1 month later...
Sorry back up for sale. Just to be clear, you will need to fabricate your own cooling runners from speedflow lines or whatever you like.
Have a look at the Otkau garage plenums for reference.
  • 6 months later...
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
    • I think Fitmit had some, have a look on there (theyre Australian as well)
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
    • Actually, I'd say all three are the automatic option. Just the different trim levels. The manual would be RSFS, no?
