9 minutes ago, Chris Rogers said:
thanks. think I will try to find one off a LS based truck here. they wound a few of those to 230A.
Just check first if they are interchangeable. The ls1 in commodores have different drive pulley offsets to the other variants in the states, and are mounted in a different location so potentially not interchangeable for 2 reasons
  • 3 weeks later...
43 minutes ago, Roy said:
What pistons? If CP they appear to be about the same piston shape as mine. I've had to pull the engine out of my old bus so sifting through parts at the moment
Yup. 9.0:1 CP from Spool Imports.
But the piston sits above the deck by about 30 thou; so we had to run a thicker head gasket.
  • 3 weeks later...
With the help of a few mates engine & clutch is in!!!
Had some trouble with the ATI balancer I got from Erics Performance in the USA.
It's supposed to suit R33 GTS-25T i.e. ECR33 but the pulley for the PS pump is 4 rib, whilst my factory S1 R33 PS pump is 3 rib.
I've emailed them to explain and see if they can send me the correct pulley. I spent enough on it assuming it was to suit the engine/PS pump combination so I'm hoping they sort it out.IMG_20200202_113942.thumb.jpg.c154e4c6e852e12c4c15b1285016259b.jpgIMG_20200202_155519.thumb.jpg.968fc486262b4a06fb45c804a565f4b5.jpgIMG_20200202_155526.thumb.jpg.05dd78dce1ec07e0a6a16bca9be95580.jpgIMG_20200202_162051.thumb.jpg.6187d2172bb51fa45453823f8d851984.jpgIMG_20200202_113942.thumb.jpg.c154e4c6e852e12c4c15b1285016259b.jpg
Transmission is in....
What a c you next Tuesday.
The cheap asses at Nissan couldn't even include a slave cylinder with a brand new transmission.
I upgraded the clutch fork and pivot ball whilst I was there to a Z33 item and Nismo pivot ball to suit the fork.
Will need to make new power steering hoses too. The R33 lines to suit the rack and pump go behind the oil pan but infront of the subframe.
Unfortunately with an extended pan there is no room to remove them if the ever needed to.
So going to get the HR31 lines and the R33 line as a template and get some made up to suit the rack and pump.
Next up is some easier stuff. Going to focus on plumbing for the intercooler and radiator.
By then should be able to work out where to run the oil filter and lines for oil cooler.
Edited by Wheezy
I will be watching to see how you do the cooler and keep the front area with AC intact. I'm swapping to a R33 condenser myself. that locates the majority of the stuff in the way on the factory item OUT of the way when the R33 is used. seems it was a popular mod with the GTS-R guys two dump the twin coils they used from factory.
I never has AC in this car. It's possible to retain. But I think you need to invert the intercooler or run gtsr style AC lines?
Im doing it with a return flow cooler and R33 AC stuff. get a 33 next to yours and measure. its DAMN close. so mine will be all 33 gear with custom lines to the car. only way I can see to do it. I need AC here in TX. my cooling fans are also 2 speed electric ex A32 Maxima.
  • 1 month later...
Fitted the oil cooler, remote oil filter, fuel pressure regulator and re did the lower intercooler mounts.
Dummy fitted the intercooler pipes. So far the hot side lines up with the new turbo.
Will need to check the intake side when I dummy fit the plenum.
I also had to buy new injectors as the spray pattern on my 1150s were sub par due to sitting for a while with E85.
Went 1650s for future headroom [emoji16]
Just need to do the oil cooler lines, fuel lines and new power steering lines.
Then start on the wiring with my brother in law.
  • 1 month later...
R33 booster arrived on Friday as the HR31 turbo booster is physically massive and fouls on the plenum (so much so I couldn't fit it).
Got the intake on and there is plenty of room now!
I had a 33 booster spare years ago and sold it, should have fitted it years ago and not had the old rb20 plenum get scratched up fitting it.
You can see the difference between the boosters.
Anyone that wants a HR31 Turbo booster with BM44 from an  R33 hit me up. I'm keeping the BM50 on the car :)
Ran into some trouble yesterday however.
The aluminum casting of the power steering pump feed is quite porous.
Broke it when tightening the AN fitting I welded onto it last weekend.
Can get a billet piece from the US but they a seem to be NLA. Anyone know where I can source?
https://suspiciousgarage.com/collections/hoses-and-fittings/sr20de
It's a 34mm spacing and I don't think another genuine one is a good thing.
Perhaps, I might be able to use a 38mm turbo return and drill out the bolts to 8mm.
Edited by Wheezy
Spoke to Roy outside SAU as for some reason I couldn't login recently. Went Nitto.
My PS feed adapter didn't turn up so ordered another one from another vendor and its due tomorrow.
So PS lines should be done and dusted this weekend.
Did some heat wrapping instead on the weekend, lots of swears.
List of things to do before getting it turned over is getting shorter and shorter rather than longer for a change!
Also looking to ditch the PowerFC ASAP and going something more modern. My wedding anniversary present :)
No Haltech or anything tech for that matter.
Power Steering cooler is in, just need some more heat sleeve to protect the paint near the rad support and keep things tidy.
Am waiting for some billet hose separators to keep the lines tidy.
Next weekend I'll be finishing the fuel system.
It's my first time doing teflon lines but I think some more video tutorials and I'll be AOK.
Then at the end of the month, with the help of a mate I'm swapping in a super clean R32 GTR engine wiring loom to get it running on. (20 loom is a bit of a rats nest IMO).
Also found out my old man has a welder which can do Tig (I only have Arc here) so getting a torch for it and going to do the new intake pipe myself as I've been practicing on stainless with the guidance of my brother in law.
With any luck, I'll have it on the dyno by EOFYS in time for the new ECU :) (famous last words)
  • Like 1
Getting to the pointy end now, not much to go!
Good luck with the welding, I've just started a bit here and there over the last two weeks (to get my exhaust hooked up) and I gotta say, I suck haha. I'm realising the preparation is important as well which I now know I haven't been doing enough of. Slowly figuring it out.
Like anything, good tools are key. The quality of my braided lines has vastly improved since getting a decent of spanners and a proper vice tool to hold the fittings.
I've got an experienced person guiding me on welding technique, equipment, settings etc. But I must say, 20 years since I last did arc/mig and I remember why I hate those.
Tig is slower but for what I'm doing its the most elegant solution.
Swapped the semi slicks onto the new wheels.Rear hubs done and wheels fitted.
Front hubs didn't get finished in time so I'll put them on in the week.
Should be finishing the wiring and fuel system this weekend coming.
Then it's just intercooler pipes, trims and panels before to go I book it for a tune.
Also sorted out a Tig torch and regulator to put on my old man's welder.
Hired an argon bottle for $10 p/m so I can start practicing before I work on the new intake pipe and intercooler pipes to the plenum
Car is rolling again on the 5 stud wheels.
I spent Saturday with a couple of mates swapping the RB20 (R32) loom for an RB26 loom out of an R32 GTR.
A basic sensor check was AOK and the fuel system primes and pressurises. Have a hose leak under the back of the car which needs looking at. The lines are fairly new and E85 compatible gates stuff so hopefully haven't perished.
Still have some small things to tidy up on the loom (wrapping & mounting) and put the dash back together but it all looks to be working as designed.
I should be able to start the car up on the PowerFC in the next couple of weeks and get the Emtron fitted at Chequered once it's taken for its run in and tune.
  • Like 1
    • You just need to remove the compressor housing, not the entire turbo. I would not be drilling and tapping anything with the housing still on anyways.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
