Has anyone got  a contact number for Red Sun Performance. Or a street address.
Has anyone had dealings with them. Are they just slow?
They are located in Ravenhall Victoria.  https://www.redsunperformance.com.au/
I bought some parts weeks ago and not getting much communication now they have my money.
Thanks Brad
https://www.sau.com.au/forums/topic/477427-red-sun-performance/
I finally had a reply email after 2 weeks of sending them daily messages.
They said they were extremely sorry for the delay.
The problem was the Recaro rails were picked up by the wrong courier and turned into a mess.
They didn't want to bother me with there problems. As you all know when money changes hands. You start thinking have they scammed me when they don't communicate.
Communication should be number one no matter where the process is at or what's gone wrong. Most are pretty understanding as long as you keep them informed. 30 second phone call.
Sounds like a poor cover up story tbh.
  • Like 1
  • 4 weeks later...
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
