Hello,
So I bought a relatively stock R34 GTR and after 500kms (all was working fine) the engine just shutdown on the highway.
The engine is cranking but refuse to start again.
So in the correct order, I checked using the supplement service manual:
-no engine light at any moment
-fuel pump (I can hear it when I switch on the key and the fuel pipe gets hard)
-checked all the fuses next to the throttle pedal and also in the engine bay
-self diagnostic give me error 55 (so no malfunction)
-I have 12V to the coil ignition on the power pin of this coil
-I don't have an oscilloscope however when cranking the engine I must see like 0.06V to 0.09V on the command of the coil ignition using a multimeter but I got 0v on each command of the spark plug
-wiring of the ignition coil is okay (continuity test)
-There was an aftermarket ignition control box (adic siccle advanced ignition control) connected to the ECM; so I removed it however after doing so I got error 20 ? (the orignal hairness seems to be intact !)
-I open the ECM but didn't find anything bad (bad soldering, blow components ...)
So this investigation supposed that the ECM is not working properly ?!
Question :
-what is error code 20 ?
-if the ECM is working fine; what are the causes that avoid it to command the ignition coils ?
There is also an aftermarket alarm I normally desarm it (using the key fob) code alarm PF7600 I don't think there is a relation to my problem but I mention this.
Thanks for any hint
https://www.sau.com.au/forums/topic/477754-r34-gtr-no-sparks/
There is no ECU code 20 for GTRs, unless they've added some secret sauce to the R34 that wasn't in the earlier ones. (although 21 is the ignition circuit.....you sure you got 20 and not 21?)
A multimeter cannot be substituted for an oscilloscope unless you're looking for a steady voltage. They are not fast enough to see brief signals.
I would say the ADIC is responsible. You'd best base your research around it.
Edited by GTSBoy
My GTR was build in 08/1999
Well I'm sure it's 20; two long blink followed by a pause of like 5 seconds and then again 2 long blink.
Yes I know for the multimeter but that's only what I've got for the moment...but I should see at least some variation on the voltage which is not the case; I measured 0V continuously. I will borrow a scope and try again.
I don't get any information on the ADIC :/
Like I said before removing it I got 55 and after removing it I got 20
Can you elaborate choyda ?
Thanks for the help I really appreciated it
Edited by bigboss59400
CAS is the thing on the end of the camshaft that tells the ecu when to fire the plugs and injectors. If you are going to take it off and haven't got a timing light mark it carefully so you that if its ok you can put it back in exactly the same position. Turn it by hand to feel if the bearings are stuffed. With the key on turn it and see if it fires the plugs (maybe pull one out and look for a spark (making sure it has a good earth). If it does look inside the cas and the end of the cam shaft to see if the drive has been damaged.
21 minutes ago, GTSBoy said:
Yes, because there are no codes ending in zero.....
I didn't noticed that thanks!
22 minutes ago, GTSBoy said:
And ref the root cause - probably ground the drive off the end of the cam, by the looks of all them chips in there.
Okay I will remove sensor and see
On 7/15/2019 at 3:20 AM, bigboss59400 said:
Just for information I found some on aliexpress
They look OEM I will buy and see
Thanks for all
There are basically two - one with plastic cap like yours Hitachi 2371 5L 300
The other one is a Mitsubishi with metal cap 2371 02U11 which will not work.
Have a look at the end of the camshaft and see if the drive appears to be damaged.
    • The car/ECU will have all the sensor that it needs and expect to have. I think i do not have to explain to you how the Link is way better specialy if you have swapped engine   I just do not want to deal with any "problems" cuz i have only Nistune which i learned is not that great and in my case cant even deal with that speed problem (Link can) And of course it will be way more easier to tune and diagnose and safe. And for the ECU/speed problem...i dont know.
    • Per Mark Roberts of Sonictune: Mark Robert Author At this time, no. No ETA either 2016-17 models. You will be able to purchase and install a 2018.5+ TCU though   TCU purchasing and pricing info! As we near the release of TCU tuning, I am going to answer some questions I get asked often.   What do I need for TCU tuning? At this time, you will need a 2018.5+ TCU to be able to tune. If you have a 2016-to early 2018, you will need to replace your TCU with the newer version. One good way to know if your TCU is good is if you have auto upshift in manual mode in 1st gear around 6500 rpms. If your manual 1st gear goes to 7k rpm and will hit the rev limiter unless you shift, you have the older TCU.   Why do I need to buy another ecu license/phone flash if I already have it on my ECU tune? The TCU is its own computer module. It is completely separate from the ECU. Because of this, you will be required to purchase a TCU license and, if your tuner has it, the phone flash license required to tune it via phone/bluetooth.   Do I need TCU tuning? TCU tuning is NOT required. However, the faster your setup, the more it will assist in track and dragy time consistency.   If I’m ECU tuned by (tuner A) can I get my TCU tuned by (Tuner ? Yes, since it’s a different module and a completely separate flash, you can have two different tuners. However, it is highly recommend that you have both tuned by the same tuner. For me, my TCU tuning will directly complement my ECU tuning style and features and running my ECU and another TCU or vice versa MIGHT cause some issues. At this time and for the foreseeable future, I will only be tuning my current ECU tuned customers TCUs.     I have a SYVECS AWD controller. Do I still need it? Yes! The AWD controllers main job is to control your AWD system. However, with TCU tuning, you will no longer need the auto-shift function as that will be done through the TCU. The AWD controller will still be very beneficial for racers looking to maximize traction on the launch.     Shift schedule changes: holding gears longer at lower pedal input as well as max shift rpm changes. Please note, the new ECU race rom coming out will address 90% of the shitty drivability issues these cars have through custom maps from myself and Racebox—as well as others I am sure.   Increase shift speeds: as seen in the videos I’ve been posting, the TCU shifts much faster once tuned.   Increased shift pressures: as also seen in the videos, much firmer full throttle shifts.
    • The fancy pants red shock tower brace is finally incoming from MX5 Mania, getting it shipped from 'Merica has been a long and problematic process, and GWR, the 'Merican supplier will not ship directly to consumers outside of the US, Mania basically had to order a heap of them, the colour choice was silver, or red, and we all know anything red adds 5 killerwasps of dynotorques..... Whilst it does fit over a 2.5, and I've seen a few photos and videos of it being installed and fitting, google also says it might get real close to the FAB9 intake front runner, people in the US says it does fit with the FAB9 intake, except for one person who said it slightly touched.......so there is that.....LOL..... As it seems that I am the first in AU to have this combination of parts there's no local knowledge about fitment, so I'm just a willing guinea pig in this endeavour, I'll cross my fingers and toes and hope for the best In other news, I ordered stuff from China  on the same day I ordered the 23° silicone bend from Victoria, the stuff from China arrived a day ago, the 23° silicone bend is still travelling around Australia thanks to Australia Post, and "may" be here next week
    • Very good news...I contacted Racebox about it last night. My car is a 2016 so remains to be seen if it is compatible, requires a TCU swap, or is impossible.
