57 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
well some people may remember my blue R32gtst at the dyno day at Selectmaz and how it was pinging on the dyno.
i was quite dissappointed with this and set out to fix the problem...
here's the symptoms i had:
- car pinged on the dyno
- car had a slight miss at idle which got worse as the car got warmer
- car stalled at low rpm sometimes inthe first 5 mins of driving
what do you think the problem was? could have been a number of things explaining the above symptoms, and they were not necessarily related...
let's see how the armchair tuners go here :)
cheers,
Waz.
https://www.sau.com.au/forums/topic/47797-car-fixed-the-problem-was/
  • Replies 40
Nobody has voted for timing yet........
i bet it's a trick question and it was really the timing!
.. damn, it's too late to change my vote, so i'll stand by the spark plugs.
K - yes they have :cheers:
i'll go timing for arguements sake, but i reckon it could also have been the spark plugs
As long as it's fixed it's all good true?
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
