The Z-Tune is finally HOME - After the what felt like an eternity of waiting the car has arrived in showroom condition. Some of you may have even seen it at GT-R Festival! Thank you to those who did stop by our stand to say hello!
Our guys will be in soon to polish & protect it up to 110%.
Here are some photos in the meantime straight off the truck and into our workshop.
  • Like 4
Stunning - car looks amazing team - well done - a great outcome and another incredible restoration by Omori factory.
How were they with the restoration - did you get much choice on what you wanted to do with it, or was it largely a refresh and refurb?
Great collectors car that hopefully gets to see more shows and driven a bit. Well done.
  • Like 1
Nismo were fairly lenient on what options we had, though we let them make the majority of the decisions - after all, it is a Nismo restoration. We did convince them to let us change the colour, add the Nismo Carbon Intake Piping Kit - but didn't allow us to add the Nismo Carbon Airbox.
  • Like 2
11 minutes ago, profaine said:
Seems odd to not be able to change the airbox, I am sure they have their reasons!
Yep! Could be anything. As far as we are concerned it's literally the exact same thing, just in carbon fiber.
Exactly - which does make it hard to justify for us non z tune owners haha
  • Like 1
Fascinating they are extremely flexible on some fronts, but on others are quite strict - makes you wonder why... I'll try and track it down, there was a great blog from someone recently describing the whole process they went through getting their R34 refreshed.
Aki from http://www.r33gt-r.com/ is just getting his R33 GT-R done and dropped it off in June. He has expressed the same challenge around not having much information of the process while it is going on - so you are not the only ones.
We can only dream, even just the thought of shipping + refresh + shipping back makes it a costly exercise.
  • Like 2
http://www.bnr34gt-r.com/ ? This is quite an informative blog regardless of whether this is the one you were thinking of!
  • Like 1
That's the one - a great read - thanks Peter.
  • Like 2
Thank you for that link! We didn't hear much about the entire process apart from questions here and there to confirm various aspects. It definitely was a costly exercise.
A good read. Thank you.
On 06/08/2019 at 6:48 PM, jmknights93 said:
Any chance of those images in high res? A new desktop background would be cool.
Sure! let me know which one you want and I'll email it to you. Don't forget to give me your email! :)
  • Like 1
Those strut tops that allow you to adjust the suspension from the top as per your pics.. What are they called?
I can't find them anywhere :(
Edited by GRKGTR
  • 8 months later...
  • 3 weeks later...
Would really love to know their reasoning for wrapping the strut towers in carbon. It's doing nothing for strength/rigidity, so I feel it can only be a looks thing... but thats an odd place to start doing stuff in carbon.
tbf it seems like its the only part of the engine bay metal that you can see
Sure, but if it's a wank factor thing then there's plenty of other stuff there that they could have done - fuse box cover, washer bottle, rad shroud, etc. Strut towers are an odd place to start, especially considering it isn't really a bang up job either, it's a little bit rough compared to how gorgeous the rest of the car is.
I'm sure they had a reason, it just isn't obvious to me and I'd love to know what the Nismo designers were thinking with it.
    • HELP   Hey all, Is there an accelerator cable from another Nissan that can be used on the R33 GTST RB25DET with a Greddy forward facing plenum?  Thanks in advance  Rob
    • Or do we think it was installed to give 1 bar of boost max, all day, everyday?
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
