Hello All,
I have a quick question, I just bought some wheels for my 4door skyline, they’re 17x8 +30 and the website I bought them from (figment industries) has a thing where you put your car model in and if it has stock brakes suspension etc in it and it gives you wheels that SHOULD fit. I bought the wheels and when I went to put on the front ones, the wheel spikes hit on the front STOCK brake calipers. I was wondering if anyone else has had this problem and if so how can I fix it or what wheels do I need to get/ specs so the spokes clear the caliper. My stock wheels already are very close to the caliper as is so I’m kind of lost as to what to do. It seems the stock caliper in the front are huge! Thank you guys, I also know that people have put rpf1’s on it because I’ve seen pics of gtst’s with them but idk what specs to get to have them not hit on the spokes
https://www.sau.com.au/forums/topic/478488-r32-gtst-stock-brake-clearance/
57 minutes ago, GTSBoy said:
You need a small slip on spacer (at minimum), or a bigger bolt on spacer (because safer) to push the wheel out. But spacers are not a better idea than better wheels.
RPF1s fit fine. 17x8 +35 fit with plenty of clearance to the spoke.
Thanks for the reply! So just to be clear the rpf1’s would clear the brakes? And if I was going to go with spacers I would go with the ones that bolt on and have their own studs but the only thing that scares me about that is that the wheels would poke out too much and rub on the fenders, thoughts?
Spacers are shit. A bolt on is safer, but will definitely push the wheel out at least 10mm, probably 15 for the smallest ones you could get. a 5mm slip on would be the least change to wheel position, but slip ons are not a great idea.
RPF1s definitely fit. The above spec I posted is what is on mine, and they have fit R32 brakes, R33 brakes and now R34 brakes.
  • Thanks 1
Oh ok thank you! Do you also have huge brakes in the front ?
8 minutes ago, niZmO_Man said:
Those wheels aren't Enkei, they those Chinese made copies no?
Why not get genuine ROTA? Or better yet, non-stuffed wheels made by original manufacturer?
But yeah, spacers are illegal.
No they aren’t Chinese made copies and they costed a little more than rpf1’s matter of fact (should’ve just gotten rpf1’s I know). I just need to know if 17x8 +35 rpf1’s will clear the stock brakes, the user above already said they would so I’m gonna go with them and cross my fingers and hope they work
1 minute ago, niZmO_Man said:
Wait what? RPF1 are like $1,500 for a set. Why would you get copies with unknown QC? But hey, your car and life.
I just said they’re not copies. And no the ones I got ended up being around 1.2k and the rpf1’s were 1k for the set.
Okay. Why did you talk about RPF1 then?
What are these mysterious wheels? Cosmic yeah?
Where are they made? What's the background of the manufacturer? What standards/testing do they do?
$1k wheels clears 4 pots and has a long history, or $1.2k wheels that doesn't clear brakes is made where?
Doesn't matter, you already bought them. RPF1 easily clears 4 pot brakes. A mate bought a set for his Evo8.
Sounds like you're from USA though, 20mm bolt on spacers and maybe an AR1 rifle should do it.
No need to be so condescending. They said theyd trade out my wheels for the rpf1’s and was just looking for confirmation that they’d fit. Thanks for all your help. Be nicer.
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
    • Little update  I have shimmed the solenoid on the rack today following Keep it Reets video on YouTube. However my steering is still tight. I have this showing on Nisscan, my steering angle sensor was the closest to 0 degrees (I could get it to 0 degrees by small little tweaks, but the angle was way off centre? I can't figure this out for the life of me. I get no faults through Nisscan.
    • The BES920 is like the Toyota Camrys of coffee machines. E61 group head is cool, however the time requirements for home use makes it less desirable. The Toyota Camry coffee machine runs twin boilers and also PID temp control, some say it produces coffees as good as an E61 group head machine.
