Hello All,
I have a quick question, I just bought some wheels for my 4door skyline, they’re 17x8 +30 and the website I bought them from (figment industries) has a thing where you put your car model in and if it has stock brakes suspension etc in it and it gives you wheels that SHOULD fit. I bought the wheels and when I went to put on the front ones, the wheel spikes hit on the front STOCK brake calipers. I was wondering if anyone else has had this problem and if so how can I fix it or what wheels do I need to get/ specs so the spokes clear the caliper. My stock wheels already are very close to the caliper as is so I’m kind of lost as to what to do. It seems the stock caliper in the front are huge! Thank you guys, I also know that people have put rpf1’s on it because I’ve seen pics of gtst’s with them but idk what specs to get to have them not hit on the spokes
https://www.sau.com.au/forums/topic/478488-r32-gtst-stock-brake-clearance/
57 minutes ago, GTSBoy said:
You need a small slip on spacer (at minimum), or a bigger bolt on spacer (because safer) to push the wheel out. But spacers are not a better idea than better wheels.
RPF1s fit fine. 17x8 +35 fit with plenty of clearance to the spoke.
Thanks for the reply! So just to be clear the rpf1’s would clear the brakes? And if I was going to go with spacers I would go with the ones that bolt on and have their own studs but the only thing that scares me about that is that the wheels would poke out too much and rub on the fenders, thoughts?
Spacers are shit. A bolt on is safer, but will definitely push the wheel out at least 10mm, probably 15 for the smallest ones you could get. a 5mm slip on would be the least change to wheel position, but slip ons are not a great idea.
RPF1s definitely fit. The above spec I posted is what is on mine, and they have fit R32 brakes, R33 brakes and now R34 brakes.
  • Thanks 1
Oh ok thank you! Do you also have huge brakes in the front ?
8 minutes ago, niZmO_Man said:
Those wheels aren't Enkei, they those Chinese made copies no?
Why not get genuine ROTA? Or better yet, non-stuffed wheels made by original manufacturer?
But yeah, spacers are illegal.
No they aren’t Chinese made copies and they costed a little more than rpf1’s matter of fact (should’ve just gotten rpf1’s I know). I just need to know if 17x8 +35 rpf1’s will clear the stock brakes, the user above already said they would so I’m gonna go with them and cross my fingers and hope they work
1 minute ago, niZmO_Man said:
Wait what? RPF1 are like $1,500 for a set. Why would you get copies with unknown QC? But hey, your car and life.
I just said they’re not copies. And no the ones I got ended up being around 1.2k and the rpf1’s were 1k for the set.
Okay. Why did you talk about RPF1 then?
What are these mysterious wheels? Cosmic yeah?
Where are they made? What's the background of the manufacturer? What standards/testing do they do?
$1k wheels clears 4 pots and has a long history, or $1.2k wheels that doesn't clear brakes is made where?
Doesn't matter, you already bought them. RPF1 easily clears 4 pot brakes. A mate bought a set for his Evo8.
Sounds like you're from USA though, 20mm bolt on spacers and maybe an AR1 rifle should do it.
No need to be so condescending. They said theyd trade out my wheels for the rpf1’s and was just looking for confirmation that they’d fit. Thanks for all your help. Be nicer.
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
