I Have an R34 GT N/A and I rebuilt it and converted the working engine With:
-CP Neo forged pistons
-Manley Rods
-Garret Gt3071r DDB Turbo
-Series 2 stock fuel rail and injectors
-Series 2 exhaust manifold
-SplitFire Neo coils
- New iridium NGK Plugs
-255 Walbro Fuel Pump
-Freddy Forward Facing intake
-Stock GTT R34 NEO Turbo ECU
-Many Many more....
After my conversion build with all new parts, i primed it and started on the first Crank.
CURRENT STATUS:
-Crank and starts instantly every single time and runs only when applying throttle
THE PROBLEMS
- Sounds great however it if you do not apply throttle and leave her idle, she is struggle to breathe and stutters and will die
- Jumps up and down the rev range by her self
- Cannot find a decent idle and when she does its not for long
- After reeving and she goes back down she dies
- Sometimes when reeving she break up on her own
SOLUTIONS/TROUBLE SHOOTING
- TPS sensor needed to be adjusted to get the right Ohms. After we fixed it it seemed to be more consistent when reeving and staying and holding at an RPM's and slightly better idling.
- Idle air Controller,  adjusted the screw and tried over 10 positions, although it actually really helped idling it still did not cure the dying at idle problem and finding a good idle problem.
NEXT STEP (tomorrow)
Take a look at the base/ignition timing with a timing light to the notches on the crank pulley and adjust it with the CAS sensor?
DOES ANYONE HAVE EXPERIENCE WITH IGNITION TIMING? HOW DO I DO IT PROPERLY? WHAT DO THE NOTCHES INDICATE? WHAT NOTCH DO I WANT TO BE AT?
ANY ADVICE IS GREATLY APPRECIATED
There is a good guide on timing in this thread. BUT use the no 1 spark lead not the loop at the back of the engine.
You will need a Nistune chip in your ecu, a better AFM and probably better injectors.
I take it you have properly cleaned your idle valve and have your BOV plumbed back and not venting to atmosphere.
  • Like 1
UPDATE: for anyone who may be interested and can learn from this in the future....
It was MY Idle Air controller unit and it also being not having the vacuum lines  plumbed correctly.
After this a few test drives, adjusting the idle air screw and letting the ECU learn, i am almost completely sorted
  • Like 1
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
