Got my hands on a R32 projector from a broken headlight, so I bought some spare lenses with different height to play with.  I am keeping my factory setup anyways but just curious if modern lens can improve anything compared to the 30 year old one.  I wasn't expecting much out of this experiment, but one did result in a nice surprise.
Using a 6V lantern battery, these are the results.
Factory lens: about 30 or 31mm
ZKW-R: 22.5mm
FX-R: 24mm
Q5-R: 28mm
Here is what the Q5-R looks like installed.
Here is comparing Q5-R with cheap halogen H3C bulb to a cheap aftermarket HID installed in a Saturn Sky.
Very good cut line with the Q5-R lens.  Now I will see if I can find someone with H3C sized HID to try on.
https://www.sau.com.au/forums/topic/479162-trying-on-lenses-with-r32-projector/
The issue isn't the lens, it's the whole projector. They are shit. Only useful when you chop it and use it as a bracket for a HID projector.
H3C is just H3 without ground wire. So you can use H3 HID aftermarket junk, but it will be shit. It's like adding 30 psi to a dying motor, it'll still perform poorly.
Again I agree factory projector is crap and any cheap Morimoto projector will perform much better, but that's not the point here.  If you just want something that's better and treating that as the absolute, then we should see only 2JZ in these cars shouldn't we?  (gasp!)
Edited by TXSquirrel
Here is what the light looks like with HID.  The focus is dead on and the cut line is super clean.  Not bad by just changing a $15 lens and still able to retain complete factory adjustment.
I am doing this experiment with money out of my own pocket and sharing the result.  If you think the result is helpful or just "good to know," then that's my goal because I am really doing this out of curiosity.  If you think this pointless, then that's good for you too because now you don't ever have to wonder what the outcome would be if some stubborn guy wants to try some pointless experiment with a 30 year old headlight.
  • Like 1
  • Thanks 1
Yes I agree, as that is both logical and sensible.  And to be honest this still doesn't solve the RHD vs LHD beam pattern issue for me that any retrofit projector can.  I guess the biggest benefit here is retaining full range of factory adjustment, but how much of that is really needed anyway?
I would like to mention the Morimoto Q5-R lens also fits like a glove compared to others, and the whole lens-changing process is quick and hassle free, no cutting or drilling or needing fancy bracket made.  Just 15 minutes off with the old and on with the new.
Less adjustment needed than is available for sure. But....on that topic, successful retros of proper HIDs retain the adjustment.
Nothing wrong with experimenting. Good on you for bothering to write about it here. I suggest doing wall shots with the projector at least 3 car lengths away from the wall.
That flare to the off-side is interesting, don't recall seeing it when I PnP'd a set.
You can use the R32 brackets (or chop halogen projector), so you can put HID projector and retain the factory adjustment. E.g.:
  • 5 months later...
I thought I posted a follow up to the light flare, but apparently I forgot.  I added a piece of straight metal to cover up the light deflector/bracket thing designed to produce a RHD pattern, and it cured the flare.
  • Like 1
    • Update all   thanks to the workshop manual, it lead me back to checking fuses as mentioned central locking and door open lights worked when acc was switched on. diagram attached shows two points of power 1. ACC and 2.  Batt with the later being fused (#28) I did check the fuses using a multimeter but I must have stuffed that up also. Went back and checked the batt fuse in interior fuse box and you wouldn’t believe it… a blown fuse. replaced fuse and everything is now working as it should including the climate control   thank you all with your positive insight and knowledge.
    • Where is the warning "That this thread is super old"   I just went into a 5 year old thread, went to do a reply, and couldn't see anywhere obvious a warning of it being super old
    • Duncan is correct. Pitwork (and Toyota's own cheap brand "Drive Joy") were primarily created as brands to sell other manufacturers car parts. It would be weird if Nissan sold parts for Toyota vehicles with a Nissan logo on it, so they created Pitwork to sell parts for other brans Toyota, Honda etc. They are not the same as Nissan genuine parts, although they *do* meet Nissan's standards for replacement parts. They aren't supposed to be a substitute for genuine parts, but a cheaper alternative that is better than Ebay fake parts from you-know-where.
    • Thanks GTSBoy, much easier to work with it now it's free!
    • I _think_ that one has a christmas tree or some other retainer spike into a hole in that panel under it. Come in under it with thin scredrivers and just pry it gently up. If you rip the ears off the retainer pin....so what? Just stick it back down after with a bit of race tape and carry on with life.
