Hello  Everyone,
After fully forging and building my r34 2 door rb25de neo to a turbo conversion...  i would like to do a brake disc and caliper upgrade.
I know for sure for sure for sure there IS a thread  somewhere that i read a couple weeks ago but i just spent a hour looking for it and no luck.
My question is, can i buy brake discs and calipers upgrades for a r34 GTT coupe? (cant find aftermarket shit for the NA r34)
i think i heard something like the N/A brakes on the r34 is actually r33 gtst brakes and discs.
If anyone can give me some advice or even direct me to a thread it will be greatly appreciated!!
https://www.sau.com.au/forums/topic/479250-1998-r34-gt-na-coupe-brakes/
Yes. What I can't remember is if they'd given up on 4 stud wheels on the NA by the time they got to the R34. If you have 4 stud, then it is a lot more work and stuff you need to get - because the turbo stuff is obviously 5 stud.
Nope.
NA R34s were still sliding caliper junk. R33 GTST are 4 pot Sumitomo on 296mm x 30mm rotors.
There's a lot more than one thread covering this stuff on these forums. Use google to search the forums. You will get much better results.
C'mon Dylan You need to try harder mate, I searched this forum using "4 stud brake conversion" and got 10 pages of results
Mate, you are not searching hard enough or not reading the entire threads. Try this on this forum
R34 Non-turbo Rotor Size And Pads
and it will lead you to this
http://wiki.r31skylineclub.com/index.php?title=Brake_Upgrades_Miscellaneous
Read the threads in their entirety otherwise you miss stuff.
Edited by Rusty Nuts
  • Thanks 1
if you want cheap Brembos and don't want to pay the GT-R tax, get yourself 350Z Brembos calipers, Rotors :)
They will sit a bit future out compared to the GT-R ones, but if you've already got some decent wheels you'll clear it.
Oh, here's a guide I wrote many years ago:
http://www.trak-life.com/diy-350z-brembo-brakes-conversion-nissan-skyline-r33-gts-t-gts-gts-4/
  • Like 1
  • Thanks 1
I'm also not sure if the R34 NAs went to the 14mm caliper bolts like the turbos did. If they are still at 12mm, then fitting R34 turbo calipers requires changing the threaded inserts in the calipers.
If the NAs are 12mm, the you could fit R33 calipers easily enough (on the 296mm rotor) or you could fit R32 calipers (preferably using a dogbone to push them out so you can use the 324mm rotor - which you CANNOT do nicely with the R33 caliper).
The info on 12/14mm is available on here. I just can't remember.
  • Thanks 1
Habib, if you read the guide it will make sense.
No thread inserts, those are gay.
  • Haha 1
    • Initially I thought having a pair of Recaro seats would be a big bonus, it turns out these do get a little uncomfortable on long journeys (my fault, not the seat). I had a look through the GSM Performance website at reclining seats and booked an appointment to visit their show room. I got the Recaro Sportster CS for the R34 from here, was very happy with the service received so of course a re-visit was in order. Unfortunately the two Corbeau seats I had chosen aren't on display but they had 4 other options available. Two seats dug into my back, one dug into my legs and the other was perfect. I also found out that Recaro seats use a larger bolt pattern so some adaption was required. Luckily GSM offer some universal adaptors that should solve this problem. I searched the interwebs for price comparisons and Corbeau themselves were the cheapest at £300 cheaper (for the pair). I asked GSM if they could price match, unfortunately they couldn't. I later received an email saying Corbeau would honour them the same discount, but the purchase was already made. I did however order the brackets from GSM, both arrived on the same day. I started with the passenger side seat, knowing this was going to be a little trial and error. There are 3 mounting holes at the front and 2 at the rear on these JURAN Racing seat rails.  With the adaptor brackets mounted, the allen cap bolts started to push into the seat, NOT GOOD!  The rear mounting holes lined up but there were issues at the front. The holes were 1/2 hole out, so the brackets got a tickle with the drill to modify the holes. The supplied bolts weren't going to be long enough and a spacer was needed to stop the adaptor bars from bending. A local fasteners company supplied be with some nylon spacers and longer bolts (M8x30, although these will be replaced with 35mm long shortly) A before and after I pre-drilled the front bracket before making a start on the driver's seat to save some time. And in no time at all that was in the car too. The all black seats have transformed the interior and these are MUCH more comfortable. The only downside with the new Corbeau seats is I sit a little higher, but I'll happily accept that over discomfort. The Youtube video can be found here: https://www.youtube.com/watch?v=wPyttKPktXA
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
