3 hours ago, BK said:
Depends, but sometimes yeah all 24 need replacing if you can't swap them around into different locations at all. Don't get genuine, stopped doing that a long time ago as it can cost a fortune. There are better options:
http://www.precisionshims.com.au/
ok, so I been obsessing over this whole shim thing and looking over the FSM. From what I have gathered is there are 2 things that I have to do.
1) measure the valve clearance (so I do that before I even take off the cam) and write the results going off the circled specs.
785408481_Inkedvalveclearancevalues_LI.thumb.jpg.c2730bf06bb7f2785329cba6b4494ebd.jpg
2) remove the cam and take out the shim and measure the thickness, then replace the shim that is not in tolerance of the original spec. I didn't see the original spec listed like I did for the valve clearance. (yes, I see on there now in the picture that it says to replace after every disassembly)
Note: Again, from what I have understood is: 1) measure the valve clearance 2) write the number 3) get the shim thickness 4) find the difference to in the shim and that will get me the new shim measurement to order 5) install the shim and make sure the intake is at .45mm and exhaust is at .38mm. then im good to go to reinstall the cams and move forward, correct?
I checked the ones I can check. The feeler gauges fit just right and slid in. When I tried to go up to the next size up I was forcing it in and it was bending the feeler gauge.
The instructions say to turn the crank. I'm assuming this valve clearance is to be checked when the timing belt is on to make it rotate in firing order and that's how they get checked.
When I tried to rotate the cam itself it felt difficult so I stopped and just set it all back to being timed, guess I have to wait till I get the timing belt on rotate it as a whole with the crank, then I can check em.
Just a tip make sure you are checking with 2 sets of feeler blades from each side as per the manual. A lot of people check just from one side, which is sort of fine, but I have noticed different reading between measuring from one side vs from both sides.
That is correct, that is the method I used/using (feelers from both sides).
On the intake side it is a bit more difficult due to the fuel rail etc still being on.
Exhaust side was a lot easier.
https://www.ebay.com/itm/Water-Coolant-Line-Kit-For-R32-R33-RB26DETT-GT-R-with-Stock-TB25-Twin-Turbo-/302848068128
I wanna replace the coolant lines with these. What's the longevity or experience if you all have had any.
If I could replace the hard lines for vacuum, oil and coolant that run to the turbos thatd be cool too. Any recommendations?
These look like a better buy: https://www.ebay.com/p/2274087840
Edited by Jjtxaz24
It's just a stud in a thread, but it could be seized. Couple of tricks
-spray well with penetrating oil over a day or 3
-heat often loosens these things, eg a 15sec with a blow torch
-with a nut just protruding, give it a firm hit with a hammer to loosen the threads.
if it is the lock nut coming undone from the 2nd nut you need to tighten them. If you think there is too much force and they still are not turning, try those 3 tricks
I'll give that a try.
53 minutes ago, r32-25t said:
Why are you even trying to take it out?
I was advised to change it. So I ordered the bolt and wanted to have it out before the new one got here cuz I guess these are prone to snapping.
I wouldn't say they are prone to snapping. They are prone to guys overtorquiing them when changing timing belts then they snap. It's not like a Design flaw or anything
Well in that case. I'll leave it be. Appreciate it. I wont overtighten em. Got a torque wrench and the FSM for bolt specs.
  • 1 month later...
Putting it back together sucked, rebuilding the turbos sucked too.
I fired her up and she stumbled at first but once it got going she idled good and sounds good.
Here's turbo 1 after the rebuild:
Here's turbo 2 after the rebuild, I was just using a shop vac to see if had any shaft play or whatnot :
We had to leave my house and go up the street to bleed and burp the air out of the coolant neighbor started complaining it was too loud. The timing belt is a gates so it was a little whiney when we started it. It seems good now
Here's a little backfire:
I'm getting some cut outside when I hit the higher RPMs. I have a fuel filter so I'm gonna change that out, then I'll go to updating the injectors and fuel rail and fuel pump. Another project for another time. I'll enjoy this for now.
Still got more to do on this. Having the front brake calipers powder coated to match the engine bay valve covers and cam cover. I have the rear pads and rotors  as well as front pads and rotors.
Need to get new CV boots on there. The other ones popped off that I just replaced not to long ago. I might have not clamped em down tight enough. I'll check it out tomorrow.
Thanks for all the help.
Yesterday when I let the car idle after sorting out all the little issues I didnt really hear the "lopeyness" in it. I was expecting it to sound something like this:
I have the same cams and seems like the same mods. Im pretty stock internal wise only mods that i have done is the 3" exhaust, rebuilt the stock turbos with better internals and had them balanced, the Tomei Poncams 262* 9.15 car came with mushroom intake filter, and I added the HKS BOV. not much else engine wise.
Also, I mentioned in my prior post that it seemed like it was breaking up on the higher RPMs, i'm hoping its something as simple as just some fouled plugs so Im gonna change those out today, if not what else do you guys think it can be. I do have a Nistune and can log data if that would help anyone help me.
    • I was just driving into work and while on my drive, I went to accelerate and noticed the car would sputter/hesitate and I’d hear a few pops from the exhaust before it started going faster. Then I also noticed that when I push my clutch in, the car would die. This all started happening today. Any ideas?
    • That is a lovely Volvo, just saying. Yes I should have got an 260RS when they were cheap. I do regret now.
    • ^ lots of good points made above. The thing is, "aggressive" or "flush" fitment is relative depending on how much you have been influenced by social media. My starting point is always "look at the Nismo RWD specs". That is where you should start, then start measuring as GTSBoy as sort of mentioned, because every car will be slightly different. My 8.5"+35/9.5+38 will not be "flush" enough for you because you want more "pumped" look, which is why you measure. Tyre sizes and brand/models also make a difference. Some tyres are more chunky/square, some are more rounded. That means you could get away with more aggressive offsets without rubbing. But then it also depends on your ride height. Also depends on how much your car copped damage before being shipped from Japan. So it goes back to measuring your car yourself and determining what can work. Those Nismo specs are used bacause it's a safe spec for standard car (suspension. body) with chunky tyres. But then I put 265/35 wide tyres on R34 GT-R wheels, and currently run 285/30 tyres on 18x10 wheels.
    • Sounds pretty awesome. I recommend creating a new build thread and posting all your goodness in there.
