Hi guys
have done some serious work to my engine atm:
2.9L stoker kit
Neo ultimate head
Tomei 260 camshafts
Yellow jacket coil pack
otaku garage forward facing intake plenuim with a 90mm throttle body
and I’m not even on my L plates yet
thats why I’m doing all this work so when I get my p’s I can do an actual gtt turbo not a plus t setup
so if anyone has suggestions on what I’m doing and what I could do better please let me know
but back to my main question
can you convert the internals of a gt gearbox to a gtt
ive heard there the same just internally different but want to be sure
and should I be upgrading diff and drive shaft
thanks jack
No. The NA gearbox is physically much smaller. Like half the size.
You don't need to upgrade either the diff or driveshafts. Not for strength reasons anyway, as the diff is the same strength as the turbo item and the axles are nearly as good. But.....you will want an LSD centre on a turbo.
Note that I said driveshafts. You said driveshaft, and it is not clear whether you meant the tailshaft or the axles. Not that it matters, as both are strong enough.
It's also not clear what the stroker kit and other parts are fitted to. The NA engine? A turbo engine in the shed? If you've done it to the NA, complete waste of time. If you've done it to the turbo, well, the yellowjackets are not a good choice, but beyond that, everything else is OK, if largely a waste of money.
You will need brakes. And, are you sure that you will be allowed to drive a turbo on your P's?
Hi mate
yeah meant driveshafts sorry typo
and the n/a block is exactly the same as the turbo
And do you know what ignition coils I should run
im using the n/a block as it’s the same as a det but am putting det head on top
49 minutes ago, Jacks red r34 gtt said:
Hi guys
perfect example of why not to fit that style of plenum. lost 1000rpm of response and a bucket load of power. Green is factory plenum, the others are a short runner style plenum. Bin the yellow jacket coils and get a PRP r35 coil kit.
  • Like 1
Ok thanks
just wish the stock didn’t go over the valve covers
looks ugly and is really inconvenient when working on your engine
and do r35 coils stick out of cover?
13 minutes ago, Jacks red r34 gtt said:
Ok thanks
It's really not hard at all to remove the crossover pipe as required, which is not often.
Get split fires if you want it to all fit factory. You will have trouble with yellow jackets
  • Like 1
But look at the peak gain! And how much cleaner the engine bay looks.
  • Like 1
17 minutes ago, Jacks red r34 gtt said:
Btw could you link the coil kit
cant find it
http://letmegooglethat.com/?q=Prp+Rb+coil+kit
I don't like the look of most of those plenums and fitting the new plazmaman ones with engine in is a pain with the water hose/pipe underneath.
  • Like 1
No its NOT mate, no piston oilers for a start, and past experience of these blocks found that the turbo oil supply gallery has not been drilled either, or the turbo oil drain hole as well.
Edited by Rusty Nuts
Ok lol
lucky i haven’t installed anything yet
does anyone know if you can run the det neo engine without the turbo using parts of a device engine?
1 hour ago, Rusty Nuts said:
What the hell is that???????????
It's what happens when you exclusively access the internet on a phone, type "de" and have the stupid device (the phone) think you were talking about it and autocorrect to "device".
  • Haha 2
And just so everyone knows I’m not dumb it’s just I made a sau acct less than a day ago so am still learning
and robbo I thought you meant put r35 coils in a rb
that’s why I got confused
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
    • Thanks for the quick reply. To be clear, when you say turbo shuffle do you mean turbo flutter "stustustu" or referring to something else? I had thought they were the same thing. When I wrote the post my intention was to say it wasn't a flutter/compression surge sound. My understanding was that a flutter sound would be occurring when throttle is released, whereas I can keep the throttle in the same position for this noise
