On 08/08/2022 at 12:03 PM, Dose Pipe Sutututu said:
WTF, how did that even happen
Meh, more parts at the wreckers or gumtree for me to browse through
And the more that get written of the more mine goes up in price, and for a Commodore, that is weird, but true
  • Haha 2
I sold my VT2 SS LS1 6spd with usual mods (headers, exhaust, intake, tune) around 8 years ago. Was on the market for 6.5k for around a year before it finally sold for $5600. Struggled to even get anyone to come look at it.  I see guys asking 15-20k for them now and most of them look clapped out compared to mine.
Ah, the times we're living in.
  • Like 2
The Cruise Ship is in dry dock (Autotech)
It has developed a knock in the steering, mainly on right handers, I had a look, got the shits rolling around on my back under the car without finding what is was, so sent it to Autotech so they can put it up in the air and have a good look around, I'm guessing its a rack bush
While it is there I've asked them to do the front main seal, which currently losses oil at the rate of about 1 drop per week, which is annoying.....so.......seeing though the harmonic balancer needs to be pulled.....I've asked them to fit a Melling 10296  high volume pump, because.......why not
  • Like 1
On 11/08/2022 at 9:44 PM, The Bogan said:
Nope, I has blower, so I don't need no stinking turbos
well.....
you can haz both? supercharger with twin turbos.. will make all the right noises :D
On 11/08/2022 at 10:09 PM, Dose Pipe Sutututu said:
We should roll race one evening for laughs at Roll Racing. We'll be the 2x slowest cars there too.
I'm always in for some fun
Do not get the high volume pump - You will be just pumping oil harder into the heads and through your PCV system, and emptying your sump faster. What you want is the high PRESSURE pump.
So yeah that's why not
I mean is it a real issue given how you use the car, no
Did you need to change the oil pump at all given that information also no
I've been told that high volume pump will be advantages in it as opposed to high pressure
Higher volume with standard pressure for modified unopened engines
Higher pressure + higher volume for built engines, dependant on clearances
Melling recommends the 10296 pump (18% increase)with standard oil pressure for the unopened high milage and/or modified LS1 that lives under 6500 rpm
Melling 10295: Same volume as LS1, 10% increase in pressure over LS1 based M295 oil pump.
Melling 10296: 18% increase in volume, stock pressure over M295 and 10295 oil pump.
Moroso 22120: 18% increase in volume, stock pressure over M295 and 10295 oil pump.
Melling 10355: 33% increase in volume over the 10295.
Factory GM LSA: 33% increase in volume over the 10295.
Melling 10355HV: 53% increase in volume over the 10295.
I'm confused, isn't the flow rate at a given oil pressure determined by the engine rather than the pump fitted to it? I would guess that a high flow pump will just mean more oil pressure at idle but not necessarily more oil pressure otherwise. Assuming it was already hitting the oil pressure limit for the regulator.
A higher volume (bigger) pump will "keep" the pressure up in the low RPM's, I don't need more pressure, I just need what the stock spring gives me
LS1 engines typically have minimal pressure at idle and due to the design of the pump struggle to make and keep pressure, resulting in lower than desired oil pressure at low RPM, as I'm making full boost from the minute I hit the loud pedal more volume and a better design is required to keep the stock pressure actually there
The GM LSA has a pump that runs 43% more volume because of this, no more pressure, just more volume
The issue with the OEM pump is it also cavities at higher RPM due to its design, the Melling pump has better flow paths than OEM, which stops this happening, the higher volume also can help with the cooling and valvetrain noise at low RPM
The pressure required to meet the specs comes from the clearances, if I had a sloppy built forged engine the builder would specify what pressure was needed at the bearings, which, would then mean playing with higher pressure springs as well volume, I remember Yavus from Unigroup talking about this with my old R33 when he was playing with the regulator on the Tomei high volume oil pump getting it to the pressure the builder said it needed at the bearings. ..😟...triggered......R33.....triggered.....  😟.....oil everywhere........🤯
So, for my LS1 at least, by adding a higher volume pump, with better flow paths, the stock pressure will remain stable at idle to WOT
And for around $300, it is a cheap thing to do, seeing as though the balancer is off anyway to fix the front main
Well, thats what the voices in my head say
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
