On 25/08/2022 at 10:47 AM, Kinkstaah said:
Also if you're gonna do that, buying new rims, go 15's or something for more sidewall.
I want matching rims front and rear though, so throwing some DR on my current set is where its at
The smallest the FR1 go is 17"
Unless I go for a totally different set for front and rear, which I don't, because the FR1 meet my bogan prerequisites of wheels
I did look at some 15 x 8 and 15 x 10 rims, but the rims cost a fortune and look way to drag racer for my " it's basically stock" look that I'm going for
On 25/08/2022 at 2:07 PM, Duncan said:
nothing could be more bogan mate, steelies on the back
Yeah, I did try some custom steel "chasers" all round for a while, but ended up hating them and put the stockers back on, gave them to my mate used them on his box trailer 🤣
I do have a set of 15 x 7 "chasers" in the shed, they can fit up to a 255 drag radial, but, I would only run them at the drags, running them daily would be way too "lower class" Bogan and my family wouldn't let me in the door
My family likes to consider ourselves "middle to upperclass" Bogans, hence matching Gold Simmons FR1's or bust
I'd be running the 15s with 255 et street as more side wall. The smaller side wall 17s will really require a softer spring to get it to work properly.
Chuck them on when heading out to the drags and or throw in the boot with a floor jack and change there.
If really wanting a lower 60 ft thats the easiest option.
  • Like 2
Yeah, but I don't want to run them just for the drags, I want to run them during fair weather short cruises, <100km
The only time I would run the "street tyres" would be during wet weather, or long trips away, like down to Goulburn, or interstate for holidays
Having power without traction defeats the purpose of having the power
The Toyo R888R are better than the RS4's, but, it could be better
I'm happy to replace the Drag Radials when required, I should probably get around a year out of a set if I'm using daily tyres for the long drives, the Harley gets used for short trips to and from work
In the end if I get a 11 something I'll be happy, but having traction on the street is also rather handy when push comes to shove
The 255 RS4's didn't cut the mustard
The R888R are better, but.....
No road tyre is worth it. No 17in drag radial will compete with a 15 one with more sidewall. Just wear different rims front rear at the drags. There's the reason everyone does it. Driving on the road with drag radials is shit anyway, unless you are doing massive launches at every stop, they are really only good for launches, and detrimental everywhere else. Going on a cruise with corners in it I would really advise against running a DR on the rear and a regular tyre at the front.
  • Like 2
Don't you have the race logic traction control now? So should be good for traction
We change wheels and tyres for the road section on road trip stuff. Radials aren't fun on long drives.
If you don't have miss matched wheels are you even drive a commoodore?
I get the whole it looks same wheel setup have a go with the 17s and traction control setup should be a big difference.
  • Like 1
Haven't had the RaceTCS hooked up yet, it has been sitting at Autotech because Spiro wanted to do some research first as he hasn't used one yet, apparently he contacted a mate from Haltech, who knows of the RaceTCS and actually rates it
It will probably go in to get fitted in a few months time
And whilst it's good for traction, it pulls cylinders to do it, with better tyres it won't be so aggressive
I drive the VX like it was meant to be driven, it's is a big fat boat for eating miles, which was never designed to go fast around a corner
The whole point of it is to be a cruiser, that will go fast, in a straight line, not a track car or even playing touge with the kids
My driving style is typically cruising in the left lane with the radio on loving life, only with the occasional roll on, or trip to the drags for some fun
As for daily driving with drag radials, on my old R33 I ran R32 GTR 16" Rims with 255/50 16 MT SS drag radials on the rear alot around town, they were fine in the dry as long as you ran at least 35 psi in them, again, not playing touge or race car driver on the street, just cruising around and rolling it on
Memories
  • Like 2
Booked car in to swap out my 2.5" Y pipe and 3.5" single for a 3" Y pipe and 4" single because........noise
I'm justifying it to my myself because rule of thumb math has it not being a restriction under 650 hp at the fly
So I would be irresponsible not to do it
  • Like 1
Sounds more like future proofing for more displacement 😁
How big were your headers again?
On 8/29/2022 at 2:44 PM, Kinkstaah said:
Is the car not loud enough already or
What did you say??
  • Like 1
What did you say??
What?
Speak up!
1 7/8" to 3" flange
Flange...LOL
  • Haha 1
    • looking for some help and maybe some insight on others experience with a new LSD. R34 GT ran and drive beautifully, but always alot of grip loss due to the open R200 rear end, so I just installed a new 1.5 LSD way into the stock open R200 for a ER34. Simple. Everything seemed right. I test drove for the first time this weekend. as I started to back out the garage the first time slowly with tires straight it sounded and felt like I had a loose or half disconnected drive shaft...that was clucking around loose and shaking entire vehicle, and making it feel like the trans clutch was spontaneously slipping then grabbing very roughly while just letting out pedal slowly. I backed it out went to pull forward with the same noise, shake and slip grab feeling with hesitation, I turned the tires to back out more and then pulled ahead some same thing but worst because of added wheel resistance (which that I expected) puzzled … pulling it back in checking everything over and finding nothing wrong, I tried it the next day. same thing, couldn’t believe how it shook everything again making a terrible noise and making it feel like the trans clutch was slipping and grabbing, but I got it out of garage into the driveway, got it straight, drove forward and then reveres a few times in a straight line everything shaking , causing what felt like clutch slip and grab every time, sounded like right behind front driver tire and I could feel it in the floor board with my feet,... worst right when beginning to let clutch pedal out to engage slightly, shuttering and sounding terrible along the way…I managed to slowly get down the road, babying it the whole way, once I was rolling (out of 1st) seemed to be better and between shifts, then clutch felt closer to normal…not slip/ grab etc., but back down to any stop, straight road or turning, same thing. Made no difference if all tires were straight or if I was turning. All other gauge read out correct. with in 2 miles as planned I reached the empty parking lot and performed the break in procedure that came with lsd, essentially to drive in a figure 8 a bunch.  Did this, binding chattering, and shaking the car the whole way. I drove it back home seemed somewhat normal once I was in straight line and past 10 mph or so, and I know it will “bind” on corners and cause some tires squeal when turning especially from a stop, but when I begin to move it still causes what feels like the trans clutch to slip and jerk badly as well as shaking the entire car, and sounds terrible, that I didn’t expect. I used the fluid they supplied with LSD kit and did the breaking, planning to change fluid as they suggest after breaking, but wondering will it get smoother or less aggressive with use? maybe a 1.5 is just too aggressive for normal road driving?   I have a LSD that I put in my 71 cuda when I restored it, with amazing smooth , quite yet effective results. Different style LSD but that ones a joy to drive. maybe expecting too much from this R200?
    • Join SAU NSW for a flame-grilled feed & flame-spitting cruise! Sunday 17th August 2025 3:30PM Meeting Archies Flame Grille Sylvania Waters 4:45PM Cruise Departure 5:15PM Arrival at Cape Solander Kurnell Meet Location: Archies Flame Grille Final Destination: Cape Solander Kurnell *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
