Couldn't find the exact injector but guessing would be something like these https://www.efisolutions.com.au/bosch-2000cc-fuel-injector-0-280-158-821
Spend the extra money on these, much better control at idle & cruise. Makes a massive difference when tuning if the injector is linear & comes with all the data to setup correctly
http://injectordynamics.com/injectors/id2000/
Injector choice is one thing a lot of people don't understand that is important especially with a high powered flex fuel street car.
Better off buying something that comes with all the info not just 2d deadtime/voltage offset. Want flow at diffrent pressures,min pulse width and pulsewidth adder.
Places to look for data are
https://www.deatschwerks.com/
https://fuelinjectorclinic.com/ECUData
https://www.raceworks.com.au/wp-content/uploads/2018/10/LR-RW-DATA-INJ-CHARTS.pdf
http://help.injectordynamics.com/support/solutions/folders/263533
Not to mention the Bosch 2000cc are a gas, not liquid injector, and are shit for reliability. Been a lot of bad reports about them changing flow rates after repeated liquid use, causing individual cylinder lean outs.
Lithium wrote something very detailed about them in here, I think it might be somewhere in the Borg Warner EFR thread.
  • Like 1
Well at least they are proper car injectors supplied to Ford
https://www.robietherobot.com/storm/fuelinjectorguide2.htm (sorry you have to scroll way down the page til you come to the heading "Ford")
That's right but no doubt Bosch makes various kinds of injectors. These appear to be for petrol engines but the table I found may not have all the info the OP requires. This is what Lithium was talking about:
SPECIFICALLY about "Bosch 2200cc" / ID2000 injectors.
Can't find a petrol 2000cc on the Bosch motorsport site, so is there one ? The Bosch 1550/1650cc seems to be the largest guaranteed from Bosch for petrol. I thought the Siemens 2000cc + (2400cc ?) was the only guaranteed petrol one on the market after speaking with CRD and Maatouks. They are around the $300 mark each too, a lot dearer than the Bosch 2000cc
If you follow my link you will find that they were OEM on a number of Ford cars.
Sorry you have to scroll more than halfway down the page til you get to the heading "Ford"
Yep thats right. They are also listed as flowing 252cc/min, not 2000cc. This is for part 2F1E-A7A.
I take it OP is referring to the eBay ad listing these injectors as 6 x R34 2000cc injectors for $200 ?
https://www.ebay.com.au/itm/r34-skyline-2000cc-bosch-fuel-injectors-x6-2F1E-A7A-200/124054198368?hash=item1ce234d860:g:IcAAAOSw2bRd5hmr
There does not appear to be a part number 2F1E-A7A-2000, even though they are shown on the packaging.
I suspect these are Ford Taurus 2000 model injectors, not 2000cc injectors and seller has no idea.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
