Hi there! Is it some sort of special technique to use a gasket sealant like Hondabond on a metal head gasket? Got my engine back from a builder and he used Hondabond on my Tomei metal head gasket. He says hes been using this technique since 2017.
Never heard of anyone doing this before, and my first instinct was that this was totally wrong. I tried searching the web for several days and came across *some* high HP builders using a little hondabond on head gaskets as some sort of insurance.
Pictured below is my metal head gasket with the grey hondabond coming from the sides.
https://www.sau.com.au/forums/topic/480245-metal-headgasket-seal/
If your block is straight and your head is true there will be no blow outs. I reused a Tomei Head gasket (yes the same one)  three times when I was sorting out an issue with my RB30 and it never leaked and so far as I know is still fine years later.
55 minutes ago, Marphie21 said:
Yup he says it should be all good. He's been doing it on honda engines since 2017. But he's also become a little sketchy.
That'll teach you for using a Honda engine!
4 hours ago, Marphie21 said:
"To really make sure there are no blow outs"
According to the builder.
A bit of sticky goo won't do a single thing about blow outs. That's retarded.
The best it will manage is sealing up some oil or coolant, not combustion pressure should the head gasket reach its limit
Any idea if itll do anything detrimental towards the headgasket's performance?
If it is a sensibly thin even coat I would think it is OK. But it is another thing to go wrong, so I don't do it.
If I had known he would do this i wouldve stopped him right away. Gah youre right its something thatll bug me until I actually run the engine.
Its just that to undo what he did would require upening up the engine again, getting a new head gasket, and possibly taking the block/head to the machine shop again to get it properly smooth. This Hondabond seems to have a reputation of really not coming off easily. If we try to scrape the stuff off with our tools we might scratch the head and block surfaces.
    • Cheers. Skyline is back on the menu, can’t get rid of it. It’s like a child you don’t want, or herpes
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
