10 minutes ago, GTSBoy said:
Because....2 different sized turbos implies a sequential system. An inexperienced hobbyist setting up a sequential system from scratch sounds like hilarity. Toyota and Mazda spent millions on their systems and never really got it right.
So, I'll assume you're not doing a sequential system. I'll also assume you're not doing a true compound system, seeing as the turbos appear to be planned to be on opposite sides of the engine. And also because low boost and high boost numbers quoted appear to be about 1/4 of the values that you'd expect for compound.
So, maybe just two stage compression? In which case, the GT30 is mahoosivley oversized. Either that or the GT42 is. Well, at least one side of each of them, probably.
So, then I make a sensible suggestion of binning the additional turbo and putting an original M90 supercharger back into the Ecotec system and properly twincharge it. This actually makes a lot of sense because it will do what you suggest (fill the torque hole caused by the GT42) but.....if proper sequential is out of the question, then proper twincharging is also probably out of the question.
And all of those thoughts went through my mind prior to posting my first response, and it all seemed too hard, so I just copped out and made the post I did.
Yeah all good but on my setup the gt30 will hit full boost by 2-2500 till 5-5500 that's where the gt42 will come in at about 4-4500
Does a gt30 run off 1.9L worth of exhause make that much air flow for a 3.8L engine that quickly? You could be reallly showing some guys how its done if you pull this off.
Way back in the day people did run v6 turbos with only one bank providing the exhaust flow, no idea how well that worked, and they didnt use another larger turbo in the mix like your plan has.
how does that budget breakdown? including TH400 and converter or not?
A gt30 is good turbo choice on a stock mildly worked 1.8l civic so what's it gonna do on a 3.8l with fair amount of mods to it that balance top end and bottom end? Very quick response and good top end
well sort of,the 1.8 engine puts out 1.8l of exhaust and consumes 1.8l of air, .
I  like your confidence. full boost at 2000rpm will do skids nicely
Oh yeah my cousins auto f6 bf typhoon 420rwkw with full boost at 2000rpm constantly wrestles the traction control system from any speed around or below 50/60 till 140
Edited by Bessel
Plus it’s not the turbo setup you have that’s as important as the n/a setup ->> shit n/a setup+good turbo setup= shit running car (regardless of the goodish tune)/ good n/a setup+shit turbo setup= shit running car/ good turbo and n/a setups= lambo killer
I don't get it. Is it your plan to have both your turbos connected up to both exhaust manifolds? As in, the existing crossover pipe is still there, you're just hanging the GT30 off the same exhaust supply as the GT42? In that case, you are wrong about how it will work. You will to be lucky to spool either turbo, because each one will just be a bloody big wastegate for the other one!
If your plan is to have the GT30 just running from only one bank, while the GT42 is running off the other bank, with both boosting into the same inlet system, then you are in for a different version of shit. The GT30 will then indeed be boosted by a 1.9L engine (a pretty shitty 1.9L engine though, not making as much flow as 1.8L of Honda). But that bank of the engine will be receiving the same boost as the other bank, whilst having a much tighter exhaust flow path. So the two halves of the engine won't be making anywhere near the same power.
And, if you plan to have all sorts of exhaust and/or boost switchover valving to try to make it work, then you're back in the Toyota/Mazda sequential world I was talking about, and I wish you luck.
Also don't forget the nos, 2 of the big ones. The ford boys will be frothing.
I love a good moo mang and this sounds like it's gonna be awesome and drop epic sick skids. Please upload skid vids when done. We love skids around here.
  • Like 1
    • Pressure when IDLING, is meant to be 51PSi... So that amperage value needs to go up a fair chunk... I'd personally be factoring for more like 12amp at least on those runs, and at that point you need to hope the already there wiring doesn't drop you a volt or two, as that's a lot of fuel pressure flow drop off from 13.5 to 12V! Taking idle pressure of 51psi, means the pump will be drawing a MINIMUM of 9amps all the time based on your reading of the graph (3bar base, then allowing an extra 0.5bar for boost = roughly 51psi)
    • Hi all,  I am in the market for an R200 longnose diff out of a Z31 300ZX, or S12 RSX, DR30 skyline, or similar, in a 3.9 ratio.  Preferably a late model one with the M12 crownwheel bolts.  The only easy to find advert for one of these was my ad back in 2007 when I sold it on this forum.  I sold the diff as I had sold the car it goes to, but as it turns out, after 18 years I got the car back late last year, so now I'm looking for the diff !  If anyone knows where to find a longnose R200 LSD with the M12 crownwheel bolts, drop me a line at [email protected] - Bonus paid if soomeone comes up with the original diff (stranger things have happened !).  Cheers   Ben D
    • Hi everyone, I used to post here a bit from 2004-2013, when I owned various Nissans, in particular my S12 RSX gazelle, which was sold in 2007.  As luck would have it, after an 18 year hiatus, the car found its way back to me last year, and over the past 11 months I have had the pleasure of restoring it with my kids.  One thing that I am after in particular is a 3.9 ratio R200 LSD for it.  I actually sold the one out of the car here back in 2007 , and it would be incredible if I could track down who I sold it to, so I can see how they have progressed over the years (and to be honest, to see whether I can get the diff back !).  Anyways, hi all and let me know "where are the R200 Longnose diffs all at these days ?  Cheers Ben D
    • Arms will be the same as the G35 or 350Z, but as above, there was a change in the lower control arm where it connects to the ball joint.  That said, you can remove the ball joint cone from your old ball joints and fit them to the new ball joints.  To be honest, I didn't think the ball joints themselves were different. The main ball joint is a bit awkward to replace, you really need to remove the steering knuckle to press out the old one.  Some people have used tools to remove it in place, but it just seemed too hard to get to. If you are going to press out/in that ball joint, then you may as well just replace the bushings in the LCA and the compression rod.  You can buy the compression rod bushing from Nissan, but the LCA bushes, you will need to go aftermarket. Much cheaper than buying the whole arm.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
